Introdução
Batteries tend to lose capacity over time. This guide will show you how to replace the battery of your Nixon Mission Android Wear.
O que você precisa
Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
Carefully remove the battery from the watch.
Good morning, my on my nixon mission the oring is not good, water inside. My email is Miguelrom1@icloud.com
6 outras pessoas executaram este guia.
18 comentários
Hi, would you be able to advise where to purchase a replacement battery?
same here, where to purchase a replacement battery ?
Hi! Anyone knows where to buy a new battery?
After an extensive search there doesn't seem to be any info out there about battery size…..still
Nice presentation, Thanks. I am looking for a replacement battery as well. Can anyone provide closeup images of both sides of the battery so we can try to track down a replacement? I don’t want to crack my watch open until I have the right battery!
Hi, I search a new battery too and i don’t find it ! If someone have answer that would be great!
The battery is Model : APP00169 or APP00192 made by Apack (http://www.apack.com.tw/index.php ) 3.8Vdc
You can buy it on Ebay but I don’t have find it on the website!
Hope it help you guys!
The battery size is 48mm 27mm 27mm and the capacity is 400mah. I’m trying to find a place to buy a new one but all of them cames with 2 wires and this connector has 4
Hello
I cant find in ebay the battery, some one have other part number please?thanks
I bought my replacement 162 from Aliexpress. I think the 192 is made exclusively for Nixon repair replacement only, and not available outside Nixon. They quoted over $100AUD for replacement!
APP00169 (https://www.aliexpress.com/item/10050015...)
the wiring is the opposite way around, so have to flip the battery with installation
Hello, what the installation easy with the replacement battery (AP00162) & how is that battery performance working out so far?
Thanks
SG2000 -
I only found a apack app00169 , I hope it works for nixon mission
The apak app00169 It works?My dear friend ,Tha la very mucho
Ordered to app00169. Fits well and powered it but couldn't charge it. When I connect the charger it vibrates to charge but then doesn't and just loops.
Any ideas?
According to a previous post, the wiring on the replacement battery is the wrong way around? Have you tried reversing the wires?
I'm looking for the battery source too. What an incomplete iFixit guide. Sure, show us all how to open the watch and replace the battery, and leave out the most crucial piece of information, the battery detail itself! Perhaps the Nixon Mission battery cannot be sourced privately.
