Ir para o conteúdo principal
Nixon Mission Android Wear Battery Replacement
O que você precisa
  1. Nixon Mission Android Wear Battery Replacement, Battery: passo 1, imagem 1 %32
    • Remove 4 4.5mm Phillips head screws from back side of watch using PH00 Phillips head.
  2. Nixon Mission Android Wear Battery Replacement: passo 2, imagem 1 %32
    • Remove the back plate of watch.
  3. Nixon Mission Android Wear Battery Replacement: passo 3, imagem 1 %32
    • Unclip 5 latches from motherboard using a plastic spudger.
  4. Nixon Mission Android Wear Battery Replacement: passo 4, imagem 1 %32
    • Remove the 2 3.0mm screws from motherboard using PH00 Phillips head.
  5. Nixon Mission Android Wear Battery Replacement: passo 5, imagem 1 %32
    • Carefully remove motherboard & internal screen.
  6. Nixon Mission Android Wear Battery Replacement: passo 6, imagem 1 %32
    • Remove from the motherboard the connector with the four cables.
    • Pull the cables upward and the motherboard downward as shown in the picture.
  7. Nixon Mission Android Wear Battery Replacement: passo 7, imagem 1 %32
    • Carefully remove the battery from the watch.
Conclusão
6 outras pessoas executaram este guia.
Equipe
IUPUI, Team S3-G2, Harley Fall 2017 Membro de IUPUI, Team S3-G2, Harley Fall 2017
IUPUI-HARLEY-F17S3G2
Membros da 3
Autoria de 3 guias
18 comentários
Hi, would you be able to advise where to purchase a replacement battery?
Simon Seow - Responder
same here, where to purchase a replacement battery ?
peter.erdogyaraki - Responder
Thank you for your tuto.
But now, where I can purchase a new battery?
Thank you
COUTURIER - Responder
Hi! Anyone knows where to buy a new battery?
cristian.carvelli - Responder
After an extensive search there doesn't seem to be any info out there about battery size…..still
Jerry Jerry J - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 59
Duração total: 6,442
