Introdução
The grinder is the same as in many devices from Jura, Siemens, Bosch, Melitta, etc... The pictures of the grinder are therefore from a Jura, but the repair is basically the same.
O que você precisa
Remove all attachments such as water reservoir, coffee compartment lid, trestle drawer. Remove all coffee beans in the storage container.
Unscrew the five Torx T10 screws on the back.
Unscrew the two Torx T10 screws on the front edge of the heat plate.
Lift the front edge of the heat plate and slide it forward a bit to clear the tabs on the back edge.
Put the heat plate back down, but in such a way that you can reach the screws underneath.
Unscrew the two Torx T10 screws located under the heat plate.
Gently lift the upper side a bit and put it back down.
Push the side panel on the water tank back about 2 cm.
Place the side panel next to the machine. Do not remove it completely yet, the cables of the switch are still connected.
Disconnect the flat plugs from the switch. Be sure to note the order of the cables for later reassembly.
Remove the side panel.
Lift the top side slightly.
Press down the locking tab on the plug of the white sensor cable and pull off the black plug towards the front of the machine.
Press the two catches of the counterpart on the sides together and slide it out of the opening towards the back.
Now the top is free and you can remove it.
The grinder is damped with foam mats. One mat just rests on top. Remove it.
The grinder is open in front of you.
Now the grinder is free. Again take a picture, then pull out the axis of the adjuster with moderate force.
Depending on the model you will find a silicon sealing on top of the grinder ring, remove it.
Watch the fabrication signs , here green. This alignment must be restored later. Now turn the great black gear about 90 degrees counterclockwise. The grinder ring is free and can be lifted off.
The grinding cone is fastened with a long Torx T20 screw. The screw head is often covered with remnants of coffee beans. Expose the head and turn the screw out counterclockwise.
Now the bean feeder (the small white snail) can be removed. The grinder cone and drive can now also be lifted up carefully.
The grinder is usually filled with old, sticky coffee grounds. Clean everything carefully for an excellent coffee aroma.
Gently lift the felt ring around the drive shaft with a needle, then wipe it clean with a damp cloth. Do not attempt to wash it, as there is a risk that it will swell. When first used, turn it over with the clean side up.
Clean the inside of the grinder with a brush and damp cloth, and the blades with a dishwashing brush. Ensure it is properly dried before use.
Push both of the small latches alternately. Then the ring cover should come out.
Two clamps hold the grinder ring in its place, push them aside and it should come free.
Again clean everything. Press the new ring and cover in its place. With that the grinder ring is exchanged.
First insert the cleaned driver, then the three sleeves, springs and balls. Now fit the grinding cone on the three balls.
Then fit the auger, screw in central screws. When screwing in, push the cone downwards and make sure that everything meshes.
Insert grinding ring. The black gear is turned to the right again until the three marks are aligned. Then reinstall the adjuster drive shaft as it was originally.
Then install the remaining parts in reverse order.
You can set the grinding degree nicely by placing an empty roll of toilet paper perpendicular to the open mill and filling it with a few coffee beans. Plug in the plug (be careful!), choose a cup of coffee and watch as the coffee grounds fall out of the grinder.
These two pictures are no fake: Before repairing the grinder the coffee is thin and transparent. With new stones the coffee is strong and has a fine crema. The repair was a real success!
Work through the steps in reverse order to reassemble your device.
Um agradecimento especial a esses tradutores:
100%
shingle está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
