Ir para o conteúdo principal
Niu Kqi3 Max Tire Replacement
O que você precisa
  1. Niu Kqi3 Max Tire Replacement, Tire: passo 1, imagem 1 %32 Niu Kqi3 Max Tire Replacement, Tire: passo 1, imagem 2 %32
    • Use a floor jack or center stand to lift the scooter, making it easier to remove the tire.
    • Remove the sticker that covers the the Mortorq drive screw under it.
  2. Niu Kqi3 Max Tire Replacement: passo 2, imagem 1 %32 Niu Kqi3 Max Tire Replacement: passo 2, imagem 2 %32 Niu Kqi3 Max Tire Replacement: passo 2, imagem 3 %32
    • Use the pliers to remove the cotter pin and loosen the nut securing the rear wheel to the axle.
    • Use the tire lever to pry the tire off the rim of the wheel.
  3. Niu Kqi3 Max Tire Replacement: passo 3, imagem 1 %32 Niu Kqi3 Max Tire Replacement: passo 3, imagem 2 %32 Niu Kqi3 Max Tire Replacement: passo 3, imagem 3 %32
    • Remove the inner tube from the tire and rim.
    • Detach the connectors so you're able to completely remove the tire.
  4. Niu Kqi3 Max Tire Replacement: passo 4, imagem 1 %32 Niu Kqi3 Max Tire Replacement: passo 4, imagem 2 %32 Niu Kqi3 Max Tire Replacement: passo 4, imagem 3 %32
    • Insert the new inner tube into the tire and align it with the rim. Use the tire lever to carefully fit the tire back onto the rim of the wheel.
  5. Niu Kqi3 Max Tire Replacement: passo 5, imagem 1 %32 Niu Kqi3 Max Tire Replacement: passo 5, imagem 2 %32
    • Reattach the nut and secure it with the cotter pin. Slide the rear wheel back into the scooter frame and reattach the axle bolt.
  6. Niu Kqi3 Max Tire Replacement: passo 6, imagem 1 %32 Niu Kqi3 Max Tire Replacement: passo 6, imagem 2 %32
    • Lower the scooter and inflate the tire.
Conclusão
Replacing a tire on a Niu Kqi3 Max scooter is not a difficult task, but it does require a few tools and some basic mechanical skills. With the help of this guide, you can successfully replace the tire on your scooter and get it back on the road quickly and safely.
Redamsri0
Membro desde: 04/05/23
133 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 2-5, Briggs Spring 2023 Membro de CSU Los Angeles, Team 2-5, Briggs Spring 2023
CSULA-BRIGGS-S23S2G5
Membros da 2
Autoria de 2 guias
2 comentários
Hey there! Where did you find the spare inner tube? I can’t seem to find it anywhere online... Thanks!
Beeson - Responder
Yout brake calipers are not the red ones that are on my max, did you change them out with other ones?
Joshuaesp - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 48
Últimos 30 dias: 208
Duração total: 2,661
