Ir para o conteúdo principal
Nissan Versa Note Media Display System Replacement
O que você precisa
  1. Nissan Versa Note Media Display System Replacement, Media Display System: passo 1, imagem 1 %32
    • Ensure that the car is turned off.
  2. Nissan Versa Note Media Display System Replacement: passo 2, imagem 1 %32
    • Pull on the switch for indoor/outdoor air to remove it.
  3. Nissan Versa Note Media Display System Replacement: passo 3, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 3, imagem 2 %32
    • Use a spudger (or an old credit card) to gently pry the front panel away from the rest of the dash.
    • After wedging the parts apart you will see a gap.
  4. Nissan Versa Note Media Display System Replacement: passo 4, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 4, imagem 2 %32 Nissan Versa Note Media Display System Replacement: passo 4, imagem 3 %32
    • Using your fingers, start from the top of the panel and move down on either side to pry the panel open.
  5. Nissan Versa Note Media Display System Replacement: passo 5, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 5, imagem 2 %32
    • Once the panel is free from the dash, flip it over to expose the cables connected to it.
  6. Nissan Versa Note Media Display System Replacement: passo 6, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 6, imagem 2 %32 Nissan Versa Note Media Display System Replacement: passo 6, imagem 3 %32
    • Remove the top cable by simply squeezing the end and pulling it out of its socket.
    • Use a spudger to push down on the tab of the bottom cable and remove it.
  7. Nissan Versa Note Media Display System Replacement: passo 7, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 7, imagem 2 %32 Nissan Versa Note Media Display System Replacement: passo 7, imagem 3 %32
    • The front panel is now completely free from the dash and can be set aside.
    • Using a Phillips #3 screwdriver, remove the two screws on either side of the media system.
  8. Nissan Versa Note Media Display System Replacement: passo 8, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 8, imagem 2 %32
    • Carefully pull out the media system and turn it over so that the cables on its rear are visible.
    • Use your hands to pinch the tabs and gently pull out each cable.
  9. Nissan Versa Note Media Display System Replacement: passo 9, imagem 1 %32 Nissan Versa Note Media Display System Replacement: passo 9, imagem 2 %32 Nissan Versa Note Media Display System Replacement: passo 9, imagem 3 %32
    • Now the media system is completely free from the car.
    • Using a T10 Torx screwdriver, unscrew the four screws on either side of the media system.
Conclusão
Um comentário
Muy ilustrativo y de muchá ayuda, gracias
Juanmanuel - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 53
Últimos 30 dias: 95
Duração total: 4,209
