Ir para o conteúdo principal
Nissan Kicks Repair Cabin Air Filter Replacement
O que você precisa
  1. Nissan Kicks Repair Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 1 %32 Nissan Kicks Repair Cabin Air Filter Replacement, Cabin Air Filter: passo 1, imagem 2 %32
    • Remove the floor mat or any items in the passenger footwell of your car.
    • Use a trim tool on the inner panel beneath the glove box to release the clips and pry it out.
    • Place your hand on the far back of the panel to remove it.
    • It may require a hard tug to remove the panel.
    Pergunte ao FixBot
    Comentar
  2. Nissan Kicks Repair Cabin Air Filter Replacement: passo 2, imagem 1 %32 Nissan Kicks Repair Cabin Air Filter Replacement: passo 2, imagem 2 %32
    • Press the tab on the bottom of the filter lid to unlock it.
    • Open the lid and pull out the old filter.
    • You may want to wear gloves or a mask in case there is a lot of debris in the filter. (Especially if it's been a long time since you last changed the filter.)
    Pergunte ao FixBot
    Comentar
  3. Nissan Kicks Repair Cabin Air Filter Replacement: passo 3, imagem 1 %32
    • Insert the new filter with the arrows oriented correctly.
    • Start at the top edge of the filter, then push in the bottom, followed by the rest of the filter.
    • The direction of the arrows for the newly installed filter is dependent on what filter you purchase.
    • The arrows indicate the direction of air flow.
    Pergunte ao FixBot
    Comentar
  4. Nissan Kicks Repair Cabin Air Filter Replacement: passo 4, imagem 1 %32
    • Close the lid and push the bottom in until you hear it click.
    Pergunte ao FixBot
    Comentar
  5. Nissan Kicks Repair Cabin Air Filter Replacement: passo 5, imagem 1 %32
    • Replace the panel back and press firmly in the middle and around the edges to ensure it is locked in.
    • Give the panel a light tug afterward to make sure it is secure.
    Pergunte ao FixBot
    Comentar
Linha de Chegada
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 30
Últimos 30 dias: 140
Ao todo: 2,152
