Ir para o conteúdo principal
Nishiki Aero II Tire Removal
O que você precisa
  1. Nishiki Aero II Tire Removal, Removing Road Bike Front Wheel: passo 1, imagem 1 %32
    • Turn the bike upside down.
  2. Nishiki Aero II Tire Removal: passo 2, imagem 1 %32
    • Use a wrench to loosen the nut holding the wheel's axle on one side.
    • Once it's loose enough, continue removing the nut with your hand.
  3. Nishiki Aero II Tire Removal: passo 3, imagem 1 %32 Nishiki Aero II Tire Removal: passo 3, imagem 2 %32
    • After removing the nut, also remove the washer under it.
    • Keep note of how the washer has a small appendage that locks into a slot in the fork.
  4. Nishiki Aero II Tire Removal: passo 4, imagem 1 %32
    • Follow the previous steps for the opposite side.
  5. Nishiki Aero II Tire Removal: passo 5, imagem 1 %32
    • Lift the wheel up from the fork.
  6. Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: passo 6, imagem 1 %32 Nishiki Aero II Tire Removal, Nishiki Aero II Tire Removal: passo 6, imagem 2 %32
    • Unscrew the cap from the air valve.
    • Release the tire's air by pressing a thin object on the center pin of the valve.
    • A hex wrench or any blunt object can be used.
  7. Nishiki Aero II Tire Removal: passo 7, imagem 1 %32 Nishiki Aero II Tire Removal: passo 7, imagem 2 %32 Nishiki Aero II Tire Removal: passo 7, imagem 3 %32
    • Wedge a tire lever between the tire and the rim. Grab the tire with the lever's inward scoop.
    • Grab the tire's edge with the lever and pull it back to scoop the tire from the rim.
    • Keep the tire lever anchored on a spoke with the notch on the lever's opposite end.
  8. Nishiki Aero II Tire Removal: passo 8, imagem 1 %32 Nishiki Aero II Tire Removal: passo 8, imagem 2 %32
    • Repeat with an additional tire lever five inches away from the other.
  9. Nishiki Aero II Tire Removal: passo 9, imagem 1 %32 Nishiki Aero II Tire Removal: passo 9, imagem 2 %32 Nishiki Aero II Tire Removal: passo 9, imagem 3 %32
    • Repeat with a third tire lever farther around the tire.
    • Alternate lifting the second and third levers until the tire comes partway off.
  10. Nishiki Aero II Tire Removal: passo 10, imagem 1 %32 Nishiki Aero II Tire Removal: passo 10, imagem 2 %32 Nishiki Aero II Tire Removal: passo 10, imagem 3 %32
    • Wedge the tire off of the other rim with the tire levers.
    • Pull the air valve from its hole in the rim to completely remove the tire.
Conclusão
Tobias Elder
Membro desde: 04/25/13
113 Reputação
Autoria de 7 guias
Equipe
Cal Poly, Team 21-53, Johann Spring 2013 Membro de Cal Poly, Team 21-53, Johann Spring 2013
CPSU-JOHANN-S13S21G53
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 15
Duração total: 1,254
