Ir para o conteúdo principal
Nintendo Wii mini Motherboard Replacement
O que você precisa
  1. Nintendo Wii mini Motherboard Replacement, Unscrew the Bottom: passo 1, imagem 1 %32 Nintendo Wii mini Motherboard Replacement, Unscrew the Bottom: passo 1, imagem 2 %32
    • Remove the two rubber feet at the back of the console to reveal the hidden screws.
    • Remove the four 6mm Phillips #0 screws.
  2. Nintendo Wii mini Motherboard Replacement, Remove the Cover: passo 2, imagem 1 %32 Nintendo Wii mini Motherboard Replacement, Remove the Cover: passo 2, imagem 2 %32 Nintendo Wii mini Motherboard Replacement, Remove the Cover: passo 2, imagem 3 %32
    • Turn the Wii mini right-side up. Then run a plastic opening tool around the middle edge of the console to loosen the top piece.
    • Gently lift the top piece of the console and set it aside.
  3. Nintendo Wii mini Motherboard Replacement, Unscrew the Fan: passo 3, imagem 1 %32 Nintendo Wii mini Motherboard Replacement, Unscrew the Fan: passo 3, imagem 2 %32
    • Turn the Wii mini around so that the back of the device is facing you.
    • Using a Phillips #0 Screwdriver, unscrew the two 6mm screws on either side of the fan piece.
    • You may need to use tweezers to pull out the screws once they are loosened.
  4. Nintendo Wii mini Motherboard Replacement, Detach the Fan Connector: passo 4, imagem 1 %32 Nintendo Wii mini Motherboard Replacement, Detach the Fan Connector: passo 4, imagem 2 %32 Nintendo Wii mini Motherboard Replacement, Detach the Fan Connector: passo 4, imagem 3 %32
    • Using your fingers, gently pull the top of the pin connector straight up to detach the fan from the console.
    • Do not wiggle the connector or cable while removing. This may cause the connector to come loose
    • Remove the fan piece and set it aside.
  5. Nintendo Wii mini Motherboard Replacement, Power Board: passo 5, imagem 1 %32 Nintendo Wii mini Motherboard Replacement, Power Board: passo 5, imagem 2 %32 Nintendo Wii mini Motherboard Replacement, Power Board: passo 5, imagem 3 %32
    • Using your fingers, slide out the blue ribbon cable from the the top of the power board.
    • Using a Phillips #0 Screwdriver, unscrew the two 4mm screws at the top and bottom of the power board.
  6. Nintendo Wii mini Motherboard Replacement: passo 6, imagem 1 %32 Nintendo Wii mini Motherboard Replacement: passo 6, imagem 2 %32
    • Using your fingers, gently pull the pin connector to disconnect the power board from the disc drive.
  7. Nintendo Wii mini Motherboard Replacement: passo 7, imagem 1 %32 Nintendo Wii mini Motherboard Replacement: passo 7, imagem 2 %32
    • Lift the power board from the console and set it aside.
  8. Nintendo Wii mini Motherboard Replacement, Disc Drive: passo 8, imagem 1 %32 Nintendo Wii mini Motherboard Replacement, Disc Drive: passo 8, imagem 2 %32
    • Using a Phillips #0 Screwdriver, unscrew the four 6mm screws.
  9. Nintendo Wii mini Motherboard Replacement: passo 9, imagem 1 %32 Nintendo Wii mini Motherboard Replacement: passo 9, imagem 2 %32
    • Lift the disc drive out of the console and set it aside.
  10. Nintendo Wii mini Motherboard Replacement, Unscrew the Tray: passo 10, imagem 1 %32
    • Using a Phillips #0 Screwdriver, unscrew the 6mm screw at the top of the black tray.
    There is actually two additional screws at the bottom of the tray
    Serhii Mukha - Responder
  11. Nintendo Wii mini Motherboard Replacement, Remove the Tray: passo 11, imagem 1 %32 Nintendo Wii mini Motherboard Replacement, Remove the Tray: passo 11, imagem 2 %32 Nintendo Wii mini Motherboard Replacement, Remove the Tray: passo 11, imagem 3 %32
    • Using your fingers, pull the black plastic tray toward you to loosen it from the console.
    • Make sure the black square pieces are separated from the metal square pieces before trying to lift out the tray.
    • Once separated, lift the plastic tray out of the console and set it aside.
    • Trying to remove the tray before it is completely loosened may result in damage to the metal square pieces.
  12. Nintendo Wii mini Motherboard Replacement, Unscrew the Metal Casing: passo 12, imagem 1 %32 Nintendo Wii mini Motherboard Replacement, Unscrew the Metal Casing: passo 12, imagem 2 %32
    • Using a Phillips #0 Screwdriver, unscrew the eleven 5mm screws holding the silver metal piece to the console.
    • These screws are indicated by small arrows on the metal tray. (See Photo #2)
  13. Nintendo Wii mini Motherboard Replacement, Remove Metal Casing: passo 13, imagem 1 %32 Nintendo Wii mini Motherboard Replacement, Remove Metal Casing: passo 13, imagem 2 %32
    • Lift out the metal tray and set it aside.
  14. Nintendo Wii mini Motherboard Replacement, Remove Motherboard: passo 14, imagem 1 %32 Nintendo Wii mini Motherboard Replacement, Remove Motherboard: passo 14, imagem 2 %32
    • Lift out the motherboard and set it aside.
Conclusão
9 outras pessoas executaram este guia.
Kristin Anderson
Membro desde: 01/23/15
963 Reputação
5 Guias de autoria
Equipe
UWT Liner: Group 5 Membro de UWT Liner: Group 5
Community
3 Membros
10 Guias de autoria
Um comentário
Can you fit a Wii Motherboard inside this casing, and use the dvd drive, if so I have a few wiis with broken DVD drives I would like to repair and this would be a cheap solution.
Christopher Wortman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 60
Duração total: 3,969
