Introdução
This guide will show you how to take apart and replace the Wii U Pro Controller's secondary trigger buttons, the ZL and ZR buttons.
O que você precisa
Turn the controller over to reveal the battery cover.
Use the J000 screwdriver to remove the screw that secures the battery cover.
Once the battery has been removed, we will remove the 4 screws in the battery compartment and then the 4 screws around the back of the case. These 8 screws use the Y0 bit. Each of these screws are 5.5 mm.
Uma outra pessoa concluiu este guia.
