Ir para o conteúdo principal
Nintendo Wii U Pro Controller D-Pad Replacement
O que você precisa
  1. Nintendo Wii U Pro Controller D-Pad Replacement, Battery: passo 1, imagem 1 %32
    • Turn the controller over to reveal the battery cover.
    • Use the J000 screwdriver to remove the screw that secures the battery cover.
  2. Nintendo Wii U Pro Controller D-Pad Replacement: passo 2, imagem 1 %32 Nintendo Wii U Pro Controller D-Pad Replacement: passo 2, imagem 2 %32
    • Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
    • Use the spudger as a lever to pry up and remove the battery from the compartment.
  3. Nintendo Wii U Pro Controller D-Pad Replacement, Joystick: passo 3, imagem 1 %32
    • Remove the eight 5.5 mm Y0 screws.
  4. Nintendo Wii U Pro Controller D-Pad Replacement: passo 4, imagem 1 %32 Nintendo Wii U Pro Controller D-Pad Replacement: passo 4, imagem 2 %32
    • Now that you have removed all of the screws, carefully separate and remove the bottom half of the controller shell from the top half.
    • If you feel any resistance when pulling the shells apart, use a spudger to separate the left and right trigger contact assemblies from the bottom shell.
  5. Nintendo Wii U Pro Controller D-Pad Replacement: passo 5, imagem 1 %32
    • Move the right trigger and sensor out of the way.
    • Remove the 4 mm JIS #0 screw.
  6. Nintendo Wii U Pro Controller D-Pad Replacement: passo 6, imagem 1 %32
    • Move the left trigger and sensor out of the way.
  7. Nintendo Wii U Pro Controller D-Pad Replacement: passo 7, imagem 1 %32
    • Remove the joysticks and motherboard from the controller’s shell.
  8. Nintendo Wii U Pro Controller D-Pad Replacement: passo 8, imagem 1 %32
    • Carefully pull the rubber thumbsticks off of the electronic bearings to remove the joysticks.
  9. Nintendo Wii U Pro Controller D-Pad Replacement, D-Pad: passo 9, imagem 1 %32
    • Locate the two 4 mm motherboard screws, shown circled in red, with the J0 screwdriver.
  10. Nintendo Wii U Pro Controller D-Pad Replacement: passo 10, imagem 1 %32
    • Remove the motherboard and connected components. The rubber pad of the D-Pad is indicated in the image by the red arrow.
  11. Nintendo Wii U Pro Controller D-Pad Replacement: passo 11, imagem 1 %32
    • Remove the rubber pad and D-Pad button. The D-Pad can be replaced by the new D-Pad or be cleaned to improve condition.
Conclusão
3 outras pessoas executaram este guia.
Jesse Burton
Membro desde: 09/17/15
586 Reputação
Autoria de 3 guias
Equipe
IUPUI, Team 2-2, Harley Fall 2015 Membro de IUPUI, Team 2-2, Harley Fall 2015
IUPUI-HARLEY-F15S2G2
Membros da 4
Autoria de 15 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 42
Duração total: 4,443
