Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
This guide shows users how to replace defective and/or broken batteries in their Wii U Pro controller.
Remove the battery from the controller by inserting the plastic spudger into the small gap on the bottom right of the battery.
Use the spudger as a lever to pry up and remove the battery from the compartment.
When the battery is removed, use the Y0 screwdriver to remove the eight 5.5mm screws.
Four screws are located within the battery compartment (circled in red).
Four screws are located outside of the battery compartment (circled in orange)
As indicated in the picture above, the joystick is easier to replace when you move the right trigger and sensor out of the way.
Use the J0 screwdriver to remove the 4mm screw (circled in orange).
Incorporar este guia
Escolha um tamanho e copie o código abaixo para incorporar este guia como um pequeno widget no seu site / fórum.
Pré-Visualização
