Introdução
Use this guide to replace the directional pad buttons on your Nintendo Wii U GamePad.
O que você precisa
Remove the ten 8.9mm Tri-wing Y1 screws hidden underneath square stickers.
Lift up the back plate.
Take out the left and right shoulder buttons in the upper corners.
Remove the ZR and ZL trigger buttons by lifting up and sliding outward.
Lift up and remove the rubber cover for the directional pad.
Remove the directional pad buttons.
11 outras pessoas executaram este guia.
