Ir para o conteúdo principal
Nintendo Wii U Button Replacement
O que você precisa
  1. Nintendo Wii U Button Replacement, Button Replacement: passo 1, imagem 1 %32 Nintendo Wii U Button Replacement, Button Replacement: passo 1, imagem 2 %32
    • You will first need to find all the screws hidden underneath the black (or white) square stickers. They are all located on the bottom side of the Wii U.
    • Use a spudger to remove the stickers if it is difficult to peel off with your fingers.
  2. Nintendo Wii U Button Replacement: passo 2, imagem 1 %32
    • Remove the five Phillips #0 screws.
    • Remove the four Tri-Wing Y1 screws.
  3. Nintendo Wii U Button Replacement: passo 3, imagem 1 %32 Nintendo Wii U Button Replacement: passo 3, imagem 2 %32
    • Remove the CMOS battery door on the left side of the console.
    • Once the door is removed, remove the three Phillips #0 screws.
  4. Nintendo Wii U Button Replacement: passo 4, imagem 1 %32 Nintendo Wii U Button Replacement: passo 4, imagem 2 %32 Nintendo Wii U Button Replacement: passo 4, imagem 3 %32
    • Gently pry off the top lid of the Wii U.
  5. Nintendo Wii U Button Replacement: passo 5, imagem 1 %32 Nintendo Wii U Button Replacement: passo 5, imagem 2 %32 Nintendo Wii U Button Replacement: passo 5, imagem 3 %32
    • Rotate the device so that the front plate is facing you.
    • Remove the two Phillips #1 screws.
  6. Nintendo Wii U Button Replacement: passo 6, imagem 1 %32 Nintendo Wii U Button Replacement: passo 6, imagem 2 %32 Nintendo Wii U Button Replacement: passo 6, imagem 3 %32
    • Remove the ribbon cable and separate the front plate from the main console.
  7. Nintendo Wii U Button Replacement: passo 7, imagem 1 %32
    • Remove the three Phillips #1 screws.
  8. Nintendo Wii U Button Replacement: passo 8, imagem 1 %32
    • Once unscrewed, remove the black braces that hold the power button, eject button, and sync button in place.
  9. Nintendo Wii U Button Replacement: passo 9, imagem 1 %32
    • Remove the desired button(s).
Conclusão
Emily Vasquez
Membro desde: 02/24/16
908 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-2, Leahy Spring 2016 Membro de USF Tampa, Team 1-2, Leahy Spring 2016
USFT-LEAHY-S16S1G2
Membros da 3
Autoria de 14 guias
Um comentário
Anyone know what that ribbon cable is in step 6? Just regular 9 pin?
Lugi - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 57
Duração total: 5,067
