Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
Remove the first battery by pressing down on the positive end and pulling the battery out.
Remove the second battery by pushing up on the positive end and pulling the battery out.
Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
Repeat with the two bottom screws.
With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
Open the front plate like a book.
Place the plastic opening tool between the edge of the speaker and the wii remote.
Gently lift the speaker out of the body of the Wii remote.
Uma outra pessoa concluiu este guia.
