Ir para o conteúdo principal
Nintendo Wii Remote Speaker Replacement
O que você precisa
  1. Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: passo 1, imagem 1 %32 Nintendo Wii Remote Speaker Replacement, Front Cover Plate and Batteries: passo 1, imagem 2 %32
    • Flip the Wii Remote over so the battery cover faces you.
    • Push up on the bottom tab.
    • Remove the battery cover.
  2. Nintendo Wii Remote Speaker Replacement: passo 2, imagem 1 %32
    • Remove the first battery by pressing down on the positive end and pulling the battery out.
    • Remove the second battery by pushing up on the positive end and pulling the battery out.
  3. Nintendo Wii Remote Speaker Replacement: passo 3, imagem 1 %32
    • Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
    • Repeat with the two bottom screws.
  4. Nintendo Wii Remote Speaker Replacement: passo 4, imagem 1 %32 Nintendo Wii Remote Speaker Replacement: passo 4, imagem 2 %32
    • With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
    • These tabs are breakable. However, if the tabs are broken the controller will still function.
    • Open the front plate like a book.
    • Small parts may fall out as you open the front plate.
  5. Nintendo Wii Remote Speaker Replacement, Speaker: passo 5, imagem 1 %32 Nintendo Wii Remote Speaker Replacement, Speaker: passo 5, imagem 2 %32 Nintendo Wii Remote Speaker Replacement, Speaker: passo 5, imagem 3 %32
    • Place the plastic opening tool between the edge of the speaker and the wii remote.
    • Gently lift the speaker out of the body of the Wii remote.
Conclusão
Uma outra pessoa concluiu este guia.
Emily
Membro desde: 04/14/13
1.614 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 3-44, Amido Spring 2013 Membro de Cal Poly, Team 3-44, Amido Spring 2013
CPSU-AMIDO-S13S3G44
Membros da 4
Autoria de 26 guias
Um comentário
Thank you, u help me to fix it.
joon lew - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 21
Últimos 30 dias: 72
Duração total: 6,945
