Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
Remove the first battery by pressing down on the positive end and pulling the battery out.
Remove the second battery by pushing up on the positive end and pulling the battery out.
Using a tri-point Y1 Screwdriver, remove the two center 7mm screws by turning them counterclockwise.
Repeat with the two bottom screws.
With the flat end of a spudger, gently apply pressure to the tabs located on left side of the controller.
Open the front plate like a book.
Using the connector port, gently lift the motherboard about 2 cm from the base.
Grasp the edges of the motherboard and pull it straight away from the case.
27 outras pessoas executaram este guia.
7 comentários
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Where can i buy a brand new and original (not fake of course) wii remote for $20?
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
