Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Installing a Wii Remote motherboard requires the removal of the front cover plate and allows access to the B button.
O que você precisa
Flip the Wii Remote over so the battery cover faces you.
Push up on the bottom tab.
Remove the battery cover.
Using the connector port, gently lift the motherboard about 2 cm from the base.
25 outras pessoas executaram este guia.
7 comentários
This is useless because you can't just buy a motherboard. May as well buy a new remote for $20
Where can i buy a brand new and original (not fake of course) wii remote for $20?
You can buy a first party Wii remote plus for under $50 at Walmart, best buy, or online on Amazon or on Nintendos website
What is the dimension is the motherboard? I want to make a custom motherboard for the housing but I haven't managed to get int the wiimote yet as I am waiting for my tri screwdriver
