Introdução
The Wii was first released on November 19, 2006.
The model number of the original Wii remote I will be tearing apart is RVL-003.
My partner is also going to be showing how to tear down a Wii nunchuk.
The model number of the Wii nunchuk is RVL-004.
O que você precisa
Remove the battery cover from the remote and batteries inside.
Unscrew the four visible screws on the remote. These are Y1 tri-point screws.
there are two small screws that need to be unscrewed on the bottom of the remote.
23 outras pessoas executaram este guia.
6 comentários
Great guide! I took one of my remotes apart some years ago. Now, with fresh tri-wing driver in hand, I am ready to reassemble the thing. Problem: where to solder the green ground? It currently is fused to the nunchuk connector housing, but where does the other end go??? Wish I'd noted that, back then
Hello do you have tutorials for unassembly nunchuck's connector please?
I want to take the springs off the wii Remotes Back. The ones that are still in the back during Step 10.
