Ir para o conteúdo principal
Nintendo Wii Faceplate Replacement
O que você precisa
  1. Nintendo Wii Faceplate Replacement, Faceplate: passo 1, imagem 1 %32 Nintendo Wii Faceplate Replacement, Faceplate: passo 1, imagem 2 %32
    • Use a metal spudger to remove the white plastic screw covers stuck to the lower case near the front of the Wii.
  2. Nintendo Wii Faceplate Replacement: passo 2, imagem 1 %32
    • Remove the two 8.3 mm Tri-Point screws hidden under the covers you just removed.
  3. Nintendo Wii Faceplate Replacement: passo 3, imagem 1 %32
    • Remove the single 5.9 mm Phillips screw under the controller port door nearest the faceplate.
  4. Nintendo Wii Faceplate Replacement: passo 4, imagem 1 %32
    • Use a metal spudger to remove the rubber foot stuck to the side of the Wii near the DVD drive opening.
  5. Nintendo Wii Faceplate Replacement: passo 5, imagem 1 %32
    • Remove the single 5.9 mm Phillips screw hidden under the foot you just removed.
  6. Nintendo Wii Faceplate Replacement: passo 6, imagem 1 %32 Nintendo Wii Faceplate Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Carefully pull the faceplate away from the front of the Wii.
    • Use a pair of tweezers to disconnect the LED cable's plastic connector from the motherboard.
    • Remove the faceplate.
Conclusão
26 outras pessoas executaram este guia.
3Comentários do guia
Any more to do if pressing the on button does nothing, its still red power light?
Kyrre - Responder Compartilhar
Tanks for this guide Btw
Thanks for the guide, I just wish it continued with replacing the components within the faceplate, as I wanted to replace the white shell. Still helpful though!
Cynthia - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 35
Últimos 7 dias: 142
Últimos 30 dias: 431
Ao todo: 62,769
