Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Step by step in detail LCD only replacement
O que você precisa
Instruções em vídeo
Quase terminado!
Linha de Chegada
56 outras pessoas executaram este guia.
13 comentários
I need to buy a new frame for the switch not front or rear panel, where do i get one of these? the vent at the top is broken.
Andrew Hammond - Responder
You need the front panel. These are usually sold as a set of the front and back. When you do the replacement, make absolutely sure you transfer the translucent light guide (small piece of white plastic) and the adhesive speaker covers over. One good thing about this replacement is that you don’t have to remove the motherboard or even disconnect the joycon guide rails completely from the middle mounting panel. Take your time, and be very patient. This replacement means detaching the digitizer and screen.
If you can’t find the case here, you might be able to find it on Amazon.
Michael Mueller -
I thought this was going to be hard but compared to automotive this was cake thanks for the guidelines.
thungar_naughty - Responder
Can I use HY-883-4g CPU Thermal Paste Kit-6.5 W/MK CPU Paste instead of the K5-pro thermal paste? Are there other thermal paste recommendations? Thank you.
Ell Wiley - Responder
You can use any thermal paste, if you already got one. If you need to buy one, thek5 pro is our suggestion.
Daniele Carminati -
