Introdução
Step by step in detail LCD only replacement
Peças
Instruções em vídeo
Quase terminado!
Linha de Chegada
23 outras pessoas concluíram este guia.
10 comentários
Was wondering what size of adhesive strips is being used?
Nicole Lewis - Responder
At 4:00 minute in the video he just starts prying open the screen. I don’t get this step as it is not clear where exactly he starts.
Gabriel Lozano-Moran - Responder
Once the ribbon cables are detached all that’s left is to warm up the adhesive holding the digitizer so you can remove it and the LCD. You can start where ever you please but DO NOT a spunger or pick on the same side as the cables. Work on the other 3 sides of the screen and then use the leverage of the screen to remove the digitizer + LCD together from the adhesive holding it to the system.
Kyle Collins -
I need to buy a new frame for the switch not front or rear panel, where do i get one of these? the vent at the top is broken.
Andrew Hammond - Responder
You need the front panel. These are usually sold as a set of the front and back. When you do the replacement, make absolutely sure you transfer the translucent light guide (small piece of white plastic) and the adhesive speaker covers over. One good thing about this replacement is that you don’t have to remove the motherboard or even disconnect the joycon guide rails completely from the middle mounting panel. Take your time, and be very patient. This replacement means detaching the digitizer and screen.
If you can’t find the case here, you might be able to find it on Amazon.
Michael Mueller -
What is the thing you put with the syringe?
MarkAung - Responder
Is the removal of the heat sink needed? If so which thermal paste is best?
Chris M - Responder
Arctic Silver 5 Thermal Cooling Compoun
https://www.amazon.com/dp/B07NV27PDX/ref...
Paul Johnson -
This guy seems to do it just fine without removing the heatsink https://youtu.be/b3bRQMMq0jw?t=229
Does everyone just do it because one guy did it and everyone copied him?
Wesley Helton - Responder
I thought this was going to be hard but compared to automotive this was cake thanks for the guidelines.
thungar_naughty - Responder
