Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
Follow this guide to remove the left and right loudspeakers in a Nintendo Switch gaming console.
  1. Remove the four 6.3 mm Tri-point Y00 screws from the rear panel.
    • Remove the four 6.3 mm Tri-point Y00 screws from the rear panel.
  2. Remove the single 6.1 mm Phillips #000 screw from underneath the kickstand.
    • Remove the single 6.1 mm Phillips #000 screw from underneath the kickstand.
  3. Remove the two 2.7 mm Phillips #000 screws from the bottom of the device.
    • Remove the two 2.7 mm Phillips #000 screws from the bottom of the device.
  4. Remove the single 2.7 mm Phillips #000 screw from the top of the device.
    • Remove the single 2.7 mm Phillips #000 screw from the top of the device.
  5. Kits para o Nintendo Switch
    Um reparo rápido para reiniciar o jogo
    Confira kits para o Nintendo Switch
  6. Remove the single 3.8 mm Phillips #000 screw from the right Joy-Con rail. Remove the single 3.8 mm Phillips #000 screw from the left Joy-Con rail.
    • Remove the single 3.8 mm Phillips #000 screw from the right Joy-Con rail.
    • Remove the single 3.8 mm Phillips #000 screw from the left Joy-Con rail.
  7. Pull the rear panel up and off of the device. Pull the rear panel up and off of the device. Pull the rear panel up and off of the device.
    • Pull the rear panel up and off of the device.
  8. Remove the six 3.1mm Phillips #000 screws from the shield plate.
    • Remove the six 3.1mm Phillips #000 screws from the shield plate.
  9. Remove the shield plate from the device. A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. For best results, whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro during reassembly. A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. For best results, whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro during reassembly.
    • Remove the shield plate from the device.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. For best results, whenever the shield plate is removed, refer to our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro during reassembly.
  10. Pull the right loudspeaker connector straight out of the socket on the motherboard. Pull the right loudspeaker connector straight out of the socket on the motherboard.
    • Pull the right loudspeaker connector straight out of the socket on the motherboard.
  11. Gently lift the loudspeaker up by its wires and pull out at a 45 degree angle to remove.
    • Gently lift the loudspeaker up by its wires and pull out at a 45 degree angle to remove.
  12. Pull the left loudspeaker connector straight out of the socket on the motherboard. Pull the left loudspeaker connector straight out of the socket on the motherboard.
    • Pull the left loudspeaker connector straight out of the socket on the motherboard.
  13. Gently lift the loudspeaker up by its wires and pull out at a 45 degree angle to remove.
Conclusão
10 outras pessoas concluíram este guia.
Blake Klein
Membro desde: 29/01/2017
53.304 Reputação
49 Guias de autoria
Will typical PC thermal paste work? I have a lot of that lying around and I don’t want extra cost (already spending the price of the speakers for the tools alone).
Nico Robin - Responder
Has anyone tried to change the speakers for better ones? And how would that be done?
James Guzman - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 16
Últimos 7 dias: 133
Últimos 30 dias: 597
Duração total: 4,785
