Pular para o conteúdo principal
Introdução
Follow this guide to replace the battery in a Nintendo Switch gaming console.
The battery is heavily glued in and will require adhesive remover to make replacement possible.
Before disassembling your device, discharge the battery below 25%. The battery can catch fire and/or explode if accidentally punctured, but the chances of that happening are much lower if discharged.
If your battery is swollen, do not heat your Switch. Use a dropper, or syringe, to inject isopropyl alcohol (90+%) underneath the battery to weaken the adhesive. Swollen batteries can be dangerous, so wear eye protection and exercise due caution if attempting removal yourself. Take it to a professional if you’re not sure how to proceed.
  1. Remove the four 6.3mm Tri-point Y00 screws from the rear panel.
    • Remove the four 6.3mm Tri-point Y00 screws from the rear panel.
  2. Remove the single 6.1mm JIS #000 screw from underneath the kickstand.
    • Remove the single 6.1mm JIS #000 screw from underneath the kickstand.
    Mine was no longer than about 1mm.
    Nani - Responder
  3. Remove the two 2.7mm JIS #000 screws from the bottom of the device.
    • Remove the two 2.7mm JIS #000 screws from the bottom of the device.
  4. Remove the single 2.7mm JIS #000 screw from the top of the device.
    • Remove the single 2.7mm JIS #000 screw from the top of the device.
  5. Remove the single 3.8mm JIS #0 screw from the right Joy-Con rail. Remove the single 3.8mm JIS #0 screw from the left Joy-Con rail.
    • Remove the single 3.8mm JIS #0 screw from the right Joy-Con rail.
    • Remove the single 3.8mm JIS #0 screw from the left Joy-Con rail.
    Please do not use a JIS #0 bit on this kit. I ended up stripping the screw on my switch and now I won't be able to get inside. You are much more likely to remove this screw with a JIS #000 bit, like literally every other screw on this machine. Why I thought I should throughly read and follow the instructions is beyond me, because I guess this ifixit guy decided it would be a great meme to get people to ruin their switches.
    Jacob Klinkenberg - Responder
    +1, JIS #0 seems way too large; I used a #00 and that worked. I agree that #000 might have worked even better, but I saw this comment too late.
    Nikolai Knopp -
    Mine was #000 too. #0 was definitely too large. Also there are signs of blue threadlock.
    Nani - Responder
  6. Apple Watch Kits
    Screen and battery repairs just got easier.
    Comprar agora
    Apple Watch Kits
    Comprar agora
  7. Pull the rear panel up and off of the device. Pull the rear panel up and off of the device. Pull the rear panel up and off of the device.
    • Pull the rear panel up and off of the device.
  8. Remove the single 3.1mm JIS #000 screw from micro SD card board.
    • Remove the single 3.1mm JIS #000 screw from micro SD card board.
  9. Lift the micro SD card board up and pull towards you to disconnect it from the motherboard. Lift the micro SD card board up and pull towards you to disconnect it from the motherboard.
    • Lift the micro SD card board up and pull towards you to disconnect it from the motherboard.
    I cant get the card reader to stay connected to the motherboard when trying to reassemble it. Help needed.
    aNtHoNy R - Responder
  10. Remove the six 3.1mm JIS #000 screws from the shield plate.
    • Remove the six 3.1mm JIS #000 screws from the shield plate.
    Between Step 6 and Step 7, there is a missing step of disconnecting and removing the SD Card reader.
    Theo Mat - Responder
    @theomat Step 7 and 8 show the removal of the SD Card reader.
    Blake Klein - Responder
    Step 7 and 8 do not show that. It is completely missing. You show the card reader as being absent, but now how it came to BE absent. A lot of people will try to pull the shield out, presuming the reader is meant to come out with it. Why not update the guide?
    Daniel Henderson - Responder
    Are you seeing something different then what’s seen in this screenshot? https://jmp.sh/PdfdhSy
    Blake Klein -
  11. Remove the shield plate from the device. A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro. A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro.
    • Remove the shield plate from the device.
    • A thick pink thermal compound bridges the gap between the shield plate and the copper heat sink underneath. Use our thermal paste guide to remove the old thermal compound and replace it with an appropriate, thick compound such as K5 Pro.
    How do you know if the thermal paste needs to be replaced?
    Youji Hong - Responder
    I’d recommend replacing the thermal compound to ensure that the cooling system works as intended.
    When your switch starts to lag and drop FPS, if you play breath of the wild and it starts to slow down in heavy areas like the forest where you get the master sword, can i use artic mx 4 insted of the pink compound?
    Diego Soto - Responder
    I’d like to know as well if a cpu thermal compound like arctic mx-4 can be used to replace the pink compound
    Adam Stillman - Responder
  12. Insert the pointed end of a spudger underneath the white connector and pry upwards to disconnect the battery from the motherboard. Insert the pointed end of a spudger underneath the white connector and pry upwards to disconnect the battery from the motherboard.
    • Insert the pointed end of a spudger underneath the white connector and pry upwards to disconnect the battery from the motherboard.
  13. iFixit adhesive remover contains acetone, a mild skin and eye irritant. Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about possible skin irritation, put your gloves on now.
  14. Apply a small amount of adhesive remover (approximately 1 ml) evenly along the elevated edge of the battery cell. Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
    • Apply a small amount of adhesive remover (approximately 1 ml) evenly along the elevated edge of the battery cell.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
  15. Insert the flat end of a spudger underneath the battery and carefully pry upwards to separate it from the mid-frame. Insert the flat end of a spudger underneath the battery and carefully pry upwards to separate it from the mid-frame.
    • Insert the flat end of a spudger underneath the battery and carefully pry upwards to separate it from the mid-frame.
  16. Remove the battery from the device.
    • Remove the battery from the device.
Conclusão
14 outras pessoas concluíram este guia.
Blake Klein
Membro desde: 29-01-2017
45.659 reputação
48 Guias de autoria
You forgot the part where you need to remove, or at least disconnect the SD card reader, before removing the shield ;)
WiN6MaN - Responder
Good catch! should be fixed now, thanks!
Blake Klein -
Should I use new adhesive when I replace the battery? If so, what adhesive should I use?
Aaron Loyd - Responder
yes, at first I just replaced the battery but the battery would slide around. There is plastic all around the battery housing so it probably wouldn’t damage anything. I went back in and added a small piece of 3M double sided tape and have not had any issues.
John -
it would be worth noting that Nintendo has put some kind of thermal paste between the heat shield and the heatpipe/cooler on the chip. This thermal paste is much thicker than PC thermal paste and my switch was fine just pressing the 2 back together.
John - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 207
Últimos 7 dias: 1,200
Últimos 30 dias: 5,094
Todo: 26,079
