Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Nintendo Switch™ left Joy-Con : Shell replacement
O que você precisa
  1. Nintendo Switch™ left Joy-Con : Shell replacement, Shell: passo 1, imagem 1 %32
    • Remove the four Tri-Point Y00 screws from the back panel of the Joy-Con.
  2. Nintendo Switch™ left Joy-Con : Shell replacement: passo 2, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 2, imagem 2 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 2, imagem 3 %32
    • Insert an opening pick into the seam at the bottom edge of the controller (opposite the L and ZL buttons).
    • Slowly slide the flat edge of your opening pick up the side of the Joy-Con.
  3. Nintendo Switch™ left Joy-Con : Shell replacement: passo 3, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 3, imagem 2 %32
    • With the charging rail facing away from you, open the Joy-Con like a laptop.
    • Do not fully remove the back panel yet; there are still two ribbon cables connecting the charging rail to the motherboard.
  4. Nintendo Switch™ left Joy-Con : Shell replacement: passo 4, imagem 1 %32
    • Gently pry the battery connector straight up from its socket on the motherboard using a spudger. This will keep the Joy-Con from powering on during the repair.
    • Use caution while working around the vibration motor cable that runs close to the battery connector.
  5. Nintendo Switch™ left Joy-Con : Shell replacement: passo 5, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 5, imagem 2 %32
    • Insert a spudger between the battery and the Joy-Con housing.
    • Gently pry out the battery, which is lightly taped in place.
    • Be careful not to deform or puncture the battery.
  6. Nintendo Switch™ left Joy-Con : Shell replacement: passo 6, imagem 1 %32
    • Remove the three 3.5 mm golden Phillips #00 screws from the midframe.
  7. Nintendo Switch™ left Joy-Con : Shell replacement: passo 7, imagem 1 %32
    • Carefully flip the midframe over, away from the motherboard, as if you were turning the page of a book.
  8. Nintendo Switch™ left Joy-Con : Shell replacement: passo 8, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 8, imagem 2 %32
    • The ZL button is locked in place by a small ZIF connector on the motherboard. Use tweezers to flip the ZIF connector lock opposite the cable.
    • Use tweezers to gently pull the ZL button flex cable out of the ZIF connector socket. The midframe is now disconnected and can be removed.
  9. Nintendo Switch™ left Joy-Con : Shell replacement: passo 9, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 9, imagem 2 %32
    • Unlock the rail's top ZIF connector and then disconnect the cable.
    • Unlock the rail's bottom ZIF connector and disconnect the cable. We can now remove the rail from the back frame.
    • Remove the ZL button and its spring.
  10. Nintendo Switch™ left Joy-Con : Shell replacement: passo 10, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 10, imagem 2 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 10, imagem 3 %32
    • Remove the screw holding the rail in place. Remove the rail from the back frame and set it off to the side.
  11. Nintendo Switch™ left Joy-Con : Shell replacement: passo 11, imagem 1 %32
    • Remove the latch button and set it off to the side.
  12. Nintendo Switch™ left Joy-Con : Shell replacement: passo 12, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 12, imagem 2 %32
    • Depress the latch underneath the trigger using tweezers. Gently pry the trigger off.
    • Make sure to note the position of the two springs under the trigger as they will need to go back in the same spot on the new mid-frame.
  13. Nintendo Switch™ left Joy-Con : Shell replacement: passo 13, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 13, imagem 2 %32
    • Remove the screw holding the circuit board for the trigger in place.
    • Remove the circuit board.
  14. Nintendo Switch™ left Joy-Con : Shell replacement: passo 14, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 14, imagem 2 %32
    • Remove the screws holding the joystick in place.
    • Unlock the ZIF connector and remove the ribbon cable using tweezers.
  15. Nintendo Switch™ left Joy-Con : Shell replacement: passo 15, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 15, imagem 2 %32
    • Remove the joystick.
  16. Nintendo Switch™ left Joy-Con : Shell replacement: passo 16, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 16, imagem 2 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 16, imagem 3 %32
    • Remove the screws holding the circuit board for the minus and ZL buttons.
  17. Nintendo Switch™ left Joy-Con : Shell replacement: passo 17, imagem 1 %32
    • Remove the minus button.
    • There will be a rubber covering over the minus button. Make sure to put it over the minus button during reassembly.
  18. Nintendo Switch™ left Joy-Con : Shell replacement: passo 18, imagem 1 %32
    • Remove the screws holding the motherboard in place.
  19. Nintendo Switch™ left Joy-Con : Shell replacement: passo 19, imagem 1 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 19, imagem 2 %32 Nintendo Switch™ left Joy-Con : Shell replacement: passo 19, imagem 3 %32
    • Using the spudger, gently pry the rumble pack out of its housing.
    • Remove the rumble pack and the motherboard.
  20. Nintendo Switch™ left Joy-Con : Shell replacement: passo 20, imagem 1 %32
    • Remove the remaining five buttons from the shell.
Conclusão
74 outras pessoas executaram este guia.
11 comentários
This guide was very helpful! A picture of the latch location on the trigger (step 12) would have been a big help, that step took a minute because I was putting pressure on the wrong spot.
I also noticed that most of the #00 screws were more receptive to a J00 bit. Might be worth noting in the tools section since swapping between them can strip a screw.
Fitz Montville - Responder
Used this guide for reference on the tools needed, someone else pointed out to use the J00 bit instead of the P00 and I’ll second that as the fit for the screws was much better, thanks for the guide much appreciated!
Lee Whittaker - Responder
Exactly what I needed! Dropped a set of controllers on a tile flow and the rail popped out and pulled the ribbon cables too. I picked up another iFixit toolkit with some J bits to put it back together. I don’t know why I waited this long to fix it. Charged the controllers overnight and I’m up another set now!
energy96 - Responder
Others above have mentioned that they needed to use a J00 bit instead of P00, but mine did not work with a J00 and was better with a P000
Jeremy Johnson - Responder
Small thing. In the tools list, it incorrectly says Y0 while the rest of the post correctly says Y00 for the back screws.
William Doering - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 33
Últimos 7 dias: 310
Últimos 30 dias: 1,462
Duração total: 71,437
