Ir para o conteúdo principal
Nintendo GameCube Top Case Replacement
O que você precisa
  1. Nintendo GameCube Top Case Replacement, Top Case: passo 1, imagem 1 %32 Nintendo GameCube Top Case Replacement, Top Case: passo 1, imagem 2 %32 Nintendo GameCube Top Case Replacement, Top Case: passo 1, imagem 3 %32
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Top Case Replacement: passo 2, imagem 1 %32 Nintendo GameCube Top Case Replacement: passo 2, imagem 2 %32 Nintendo GameCube Top Case Replacement: passo 2, imagem 3 %32
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
    This can also be done whilst being in the normal upright position after all 4 of the 4.5mm Gamebit screws have been removed. Pull the top of the shell directly upwards and it should slide off easily.
    Less chance of snagging any wires or parts.
    Christopher Cox - Responder
Conclusão
13 outras pessoas executaram este guia.
dcarlin
Membro desde: 11/05/09
301 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-2, Maness Fall 2009 Membro de Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
Membros da 4
Autoria de 45 guias
Um comentário
Can you do a more in-depth version of the top cover? I had to clean each piece and need help figuring out where all the pieces go. Thanks
JJ Jackson - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 35
Últimos 30 dias: 167
Duração total: 24,468
