Ir para o conteúdo principal
Nintendo GameCube Motherboard Replacement
O que você precisa
  1. Nintendo GameCube Motherboard Replacement, Top Case: passo 1, imagem 1 %32 Nintendo GameCube Motherboard Replacement, Top Case: passo 1, imagem 2 %32 Nintendo GameCube Motherboard Replacement, Top Case: passo 1, imagem 3 %32
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Motherboard Replacement: passo 2, imagem 1 %32 Nintendo GameCube Motherboard Replacement: passo 2, imagem 2 %32 Nintendo GameCube Motherboard Replacement: passo 2, imagem 3 %32
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Nintendo GameCube Motherboard Replacement, Removing the back panel: passo 3, imagem 1 %32
    • Gently press down on the clips located on either side of the back panel.
    • Carefully remove the back panel from the GameCube.
  4. Nintendo GameCube Motherboard Replacement: passo 4, imagem 1 %32
    • Unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in orange) is still attached to the unit. Do Not Disconnect This Cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
  5. Nintendo GameCube Motherboard Replacement, Separate the casing: passo 5, imagem 1 %32 Nintendo GameCube Motherboard Replacement, Separate the casing: passo 5, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
  6. Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: passo 6, imagem 1 %32 Nintendo GameCube Motherboard Replacement, Remove Nintendo GameCube Optical Drive Assembly: passo 6, imagem 2 %32
    • The left side of the unit contains the cooling fan and its housing.
    • Carefully remove the two screws attaching the cooling fan housing to the unit.
    • Do not detach the red and black cooling fan wire from the main unit. Boxed in orange.
  7. Nintendo GameCube Motherboard Replacement: passo 7, imagem 1 %32 Nintendo GameCube Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the four Phillips #1 screws retaining the ground springs.
    • Carefully remove the ground springs from the main unit.
  8. Nintendo GameCube Motherboard Replacement: passo 8, imagem 1 %32 Nintendo GameCube Motherboard Replacement: passo 8, imagem 2 %32
    • The optical drive is secured to a metal plate.
    • Using a Phillips #2 screwdriver, unscrew the twelve screws that are around the outer edge of the optical drive.
  9. Nintendo GameCube Motherboard Replacement, Remove the assembly: passo 9, imagem 1 %32 Nintendo GameCube Motherboard Replacement, Remove the assembly: passo 9, imagem 2 %32 Nintendo GameCube Motherboard Replacement, Remove the assembly: passo 9, imagem 3 %32
    • Carefully separate the optical drive assembly from the rest of the GameCube unit.
    • The optical drive assembly is secured to the motherboard underneath by a slot; some force may be required to carefully free the assembly.
    • The metal plate and the actual optical drive will remain attached.
  10. Nintendo GameCube Motherboard Replacement, Motherboard: passo 10, imagem 1 %32 Nintendo GameCube Motherboard Replacement, Motherboard: passo 10, imagem 2 %32
    • With the Optical Drive Assembly removed, your GameCube should now look like this.
    • Remove the 6 screws (circled in orange) on the heat sink using a #1 Phillips screwdriver.
  11. Nintendo GameCube Motherboard Replacement: passo 11, imagem 1 %32 Nintendo GameCube Motherboard Replacement: passo 11, imagem 2 %32
    • Gently lift the motherboard from base (as shown in second picture).
  12. Nintendo GameCube Motherboard Replacement: passo 12, imagem 1 %32 Nintendo GameCube Motherboard Replacement: passo 12, imagem 2 %32
    • Carefully disconnect the ribbon cable connecting the motherboard with the front panel.
    • At this point you can replace the old motherboard with a new one and enjoy your now-functional GameCube!
Conclusão
12 outras pessoas executaram este guia.
mwbisson
Membro desde: 11/05/09
1.024 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-2, Maness Fall 2009 Membro de Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
Membros da 4
Autoria de 43 guias
3 comentários
What happens if you disconnect that cable (localizated on Step 4)?
Santi12008 - Responder
Its soldered to the front-board and the connector is on the main-board under the disc assembly, trying to remove it will break it.
Joseph Lalone -
I have been having trouble with my cube shorting out when I insert a memory card into slot A. What is the best way to get at it see if this is the case, and what should I be looking for?
Many thanks
farrell dann - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 41
Últimos 30 dias: 238
Duração total: 26,928
