Ir para o conteúdo principal
Nintendo GameCube Front and Back Panel Replacement
O que você precisa
  1. Nintendo GameCube Front and Back Panel Replacement, Top Case: passo 1, imagem 1 %32 Nintendo GameCube Front and Back Panel Replacement, Top Case: passo 1, imagem 2 %32 Nintendo GameCube Front and Back Panel Replacement, Top Case: passo 1, imagem 3 %32
    • Turn over the Gamecube so that the bottom side is facing up.
    • Use the 4.5 mm Gamebit screwdriver to remove all four screws.
  2. Nintendo GameCube Front and Back Panel Replacement: passo 2, imagem 1 %32 Nintendo GameCube Front and Back Panel Replacement: passo 2, imagem 2 %32 Nintendo GameCube Front and Back Panel Replacement: passo 2, imagem 3 %32
    • With the bottom side of the GameCube facing upward and the screws removed, carefully pull the outer shell of the unit away from the top half.
    • Move the GameCube so that the inside is facing upwards.
  3. Nintendo GameCube Front and Back Panel Replacement, Removing the back panel: passo 3, imagem 1 %32
    • Gently press down on the clips located on either side of the back panel.
    • Carefully remove the back panel from the GameCube.
  4. Nintendo GameCube Front and Back Panel Replacement: passo 4, imagem 1 %32
    • Unclip the controller ports at the front of the unit.
    • A ribbon cable (outlined in orange) is still attached to the unit. Do not disconnect this cable.
    • Controller ports are where the controllers plug into the game console, and are a half circular shape.
  5. Nintendo GameCube Front and Back Panel Replacement, Separate the casing: passo 5, imagem 1 %32 Nintendo GameCube Front and Back Panel Replacement, Separate the casing: passo 5, imagem 2 %32
    • This step may not be necessary depending on your end goal
    • Use a Phillips #2 screwdriver to remove the two screws on the back of the control port.
    • Carefully separate the gray outer casing of the control port and the circuit board.
Conclusão
6 outras pessoas executaram este guia.
dcarlin
Membro desde: 11/05/09
390 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-2, Maness Fall 2009 Membro de Cal Poly, Team 6-2, Maness Fall 2009
CPSU-MANESS-F09S6G2
4 Membros
Autoria de 45 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 26
Últimos 30 dias: 152
Ao todo: 17,785
