Introdução
The Z button is located above the right trigger but functions as a button.
O que você precisa
Place the controller (buttons down) on a solid surface.
Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
Gently lift the back panel up, separating it from the front panel.
For some reason, it was simpler to take the top half off, although it could be because it is most probably refurbished before
Grab the Z-button by the peg with tweezers and lift it out of the controller.
So how do you put it back in like the replacement because I have a controller I'm working a junker my Friend gave me and I'm trying to fix it the z button doesn't work here it's a pelican wireless controller it's actually not to bad bulky but not bad
7 outras pessoas executaram este guia.
6 comentários
My z button presses down and makes the click, but it does not actually send any input to the controller. How do you fix this?
So how do you put it back in like the replacement because I have a controller I'm working with a junker my Friend gave me and I'm trying to fix it the z button doesn't work here is a pic
My bad no pic it's a pelican wireless controller
Does that silver bar on the bottom of the Z button supposed to be there? My Z button does not have that, is it important for the button to have that?
Does anyone know where to buy the actual button for the Z button? I can’t seem to find one where the pins are further apart up top and closer together towards the bottom of the button. I only see the opposite.
