Ir para o conteúdo principal
Conserte seus objetos
Direito de executar reparos
Peças e ferramentas
Introdução
This guide will demonstrate proper removal of the D-Pad. This is necessary in order to clean or replace it.
Peças
Nenhum componente especificado.
  1. Place the controller (buttons down) on a solid surface.
    • Place the controller (buttons down) on a solid surface.
    • Remove the six 9.2mm Tri-wing Y0 screws that hold the back panel in place.
  2. Gently lift the back panel up, separating it from the front panel.
    • Gently lift the back panel up, separating it from the front panel.
    • Some of the buttons may fall out if they are knocked around.
  3. Grab the Z-button by the peg with tweezers and lift it out of the controller. During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
    • Grab the Z-button by the peg with tweezers and lift it out of the controller.
    • During re-assembly, make sure the plastic rim and spring fit into the slot provided, or else the case will not shut.
  4. Carefully unhook the cable that is looped around the peg.
    • Carefully unhook the cable that is looped around the peg.
  5. Lift the circuit board out of the controller.
    • Lift the circuit board out of the controller.
    • Do not grab the rumble motor to lift the circuit board as shown in the picture. It will in many cases just remove the rumble motor. Instead, grab the edges of the board.
  6. Remove the rubber backing with tweezers.
    • Remove the rubber backing with tweezers.
  7. Use tweezers to grab the center peg of the directional pad and lift it out of its socket.
    • Use tweezers to grab the center peg of the directional pad and lift it out of its socket.
Conclusão
3 outras pessoas concluíram este guia.
Sean Michel
Membro desde: 14-01-2013
1.648 Reputation
8 Guias de autoria
Equipe
Cal Poly, Team 19-44, Regan Winter 2013 Membro de Cal Poly, Team 19-44, Regan Winter 2013
CPSU-REGAN-W13S19G44
4 Membros
17 Guias de autoria
Adicione um comentário
Past 24 Hours: 4
Past 7 Days: 15
Past 30 Days: 47
All Time: 4,167
