Ir para o conteúdo principal
Introdução
If the battery within your Game Boy Advanced SP doesn’t last long, or if the console does not turn on at all, you might need to replace it. The following process applies to both the AGS - 100 and the AGS - 101 models of the console. If the battery has never been replaced, be careful when disassembling the unit, because the battery may have swelled over time which can be a potential hazard. Additionally, make sure that the console is not connected to a power source while performing the battery replacement process.
For a replacement battery, visit Amazon.
  1. Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
    • Use a standard Phillips #00 screwdriver to loosen the 4 mm screw that keeps the battery cover attached to the device.
  2. Lift the battery cover up and remove it from the device.
    • Lift the battery cover up and remove it from the device.
    • The screw will remain attached to the battery cover because of Nintendo's design.
  3. Use your fingers or a plastic opening tool to remove the battery from the device.
    • Use your fingers or a plastic opening tool to remove the battery from the device.
    • Caution: Please exercise caution when handling the battery. If it appears to be swelling or damaged at all it is considered a fire hazard.
Conclusão
For reassembly, follow the instructions in reverse order.
23 outras pessoas concluíram este guia.
Rocco Lattanzio
Membro desde: 11/01/2013
858 Reputação
2 Guias de autoria
Equipe
Cal Poly, Team 17-22, Forte Winter 2013 Membro de Cal Poly, Team 17-22, Forte Winter 2013
CPSU-FORTE-W13S17G22
4 Membros
32 Guias de autoria
2 comentários
This task is not very easy, its easy.
Very easy: Does not require opening device.
Easy: Requires minimal disassembly and requires a few tools like a Philips or flat-head screwdriver.
This however requires opening device.
Santi12008 - Responder
Thanks for yout guideline. I settle in 5 minutes.
aam9999 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 36
Últimos 7 dias: 176
Últimos 30 dias: 800
Duração total: 38,662
