Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
The springs located in the cartridge tray ware out over time and must be replaced. Follow our guide to show you how to remove the springs.
O que você precisa
Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
Push down on the spring with your finger and pull out of the plastic casing.
3 outras pessoas executaram este guia.
