Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Nintendo Entertainment System Game Cartridge Tray Replacement
O que você precisa
  1. Nintendo Entertainment System Game Cartridge Tray Replacement, Game Cartridge Tray: passo 1, imagem 1 %32 Nintendo Entertainment System Game Cartridge Tray Replacement, Game Cartridge Tray: passo 1, imagem 2 %32
    • Remove the six 13.25mm Phillips screws on the bottom of the game console with a #2.5 flathead screwdriver.
    • The screws are recessed about 40 mm.
    • Flip the game console right side up and take off the top by pulling it up and away from the rest of the device with your hands.
  2. Nintendo Entertainment System Game Cartridge Tray Replacement: passo 2, imagem 1 %32 Nintendo Entertainment System Game Cartridge Tray Replacement: passo 2, imagem 2 %32
    • Remove the seven 13.25mm Phillips screws from the metal cover with a Phillips head #2 screwdriver.
    • Remove the metal cover by pulling it up and away from the rest of the console with your hands.
  3. Nintendo Entertainment System Game Cartridge Tray Replacement: passo 3, imagem 1 %32 Nintendo Entertainment System Game Cartridge Tray Replacement: passo 3, imagem 2 %32 Nintendo Entertainment System Game Cartridge Tray Replacement: passo 3, imagem 3 %32
    • Remove the two silver 17.45mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Remove the two bronze 13.25mm Phillips screws from the cartridge tray using a Phillips head #2 screwdriver.
    • Slide the cartridge tray toward you, away from the 72-PIN connector, and off the motherboard assembly.
  4. Nintendo Entertainment System Game Cartridge Tray Replacement: passo 4, imagem 1 %32
    • Underneath the cartridge tray is a black tab/lip (see marker).
    • Make sure you orient this tab underneath the motherboard in addition to orienting the tray on top. Failure to do so will bow the cartridge tray and place stress on the component.
Conclusão
8 outras pessoas executaram este guia.
nicholasweiser
Membro desde: 09/22/10
2.634 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 14-40, Forte Fall 2010 Membro de Cal Poly, Team 14-40, Forte Fall 2010
CPSU-FORTE-F10S14G40
Membros da 4
Autoria de 20 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 26
Últimos 30 dias: 98
Duração total: 14,978
