Introdução
Your Cartridge-Dust-Flap is yellowed, broken, or completely gone? With this guide you can fix the appearance of your NES.
Sadly there is no Flap with the print “European Edition”, but anyways it should work fine.
Ferramentas
Peças
Remove the six 13.50mm PH2 screws from the base plate.
Now take off the upper part of the housing.
Take the top housing and turn it over.
Remove the four 7,80mm flathead screws.
Remove both metal clips.
Pull the front black cap off upwards.
Now lift the flap out at an angle.
The new flap can now be inserted.
Uma outra pessoa concluiu este guia.
Um agradecimento especial a esses tradutores:
100%
Bruno está nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
