Ir para o conteúdo principal
Nintendo DSi XL Motherboard Replacement
O que você precisa
  1. Nintendo DSi XL Motherboard Replacement, Battery: passo 1, imagem 1 %32 Nintendo DSi XL Motherboard Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
    Pergunte ao FixBot
  2. Nintendo DSi XL Motherboard Replacement: passo 2, imagem 1 %32
    • Lift the battery from the DSi XL.
    Pergunte ao FixBot
  3. Nintendo DSi XL Motherboard Replacement, Lower Case: passo 3, imagem 1 %32 Nintendo DSi XL Motherboard Replacement, Lower Case: passo 3, imagem 2 %32 Nintendo DSi XL Motherboard Replacement, Lower Case: passo 3, imagem 3 %32
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
    Pergunte ao FixBot
  4. Nintendo DSi XL Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
    Pergunte ao FixBot
  5. Nintendo DSi XL Motherboard Replacement: passo 5, imagem 1 %32 Nintendo DSi XL Motherboard Replacement: passo 5, imagem 2 %32 Nintendo DSi XL Motherboard Replacement: passo 5, imagem 3 %32
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
    Pergunte ao FixBot
  6. Nintendo DSi XL Motherboard Replacement: passo 6, imagem 1 %32 Nintendo DSi XL Motherboard Replacement: passo 6, imagem 2 %32
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
    Pergunte ao FixBot
  7. Nintendo DSi XL Motherboard Replacement: passo 7, imagem 1 %32 Nintendo DSi XL Motherboard Replacement: passo 7, imagem 2 %32
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
    Pergunte ao FixBot
  8. Nintendo DSi XL Motherboard Replacement, Wi-Fi Board: passo 8, imagem 1 %32 Nintendo DSi XL Motherboard Replacement, Wi-Fi Board: passo 8, imagem 2 %32
    • Lift the Wi-Fi board up off its socket on the motherboard.
    • Do not attempt to completely remove the Wi-Fi board yet. It is attached to the motherboard by an antenna cable.
    Pergunte ao FixBot
  9. Nintendo DSi XL Motherboard Replacement: passo 9, imagem 1 %32
    • Use a spudger to pry the Wi-Fi cable off its socket on the underside of the Wi-Fi board.
    Pergunte ao FixBot
  10. Nintendo DSi XL Motherboard Replacement, Motherboard: passo 10, imagem 1 %32
    • Use a spudger to pry the microphone cable off the motherboard.
    • Pry from underneath the cable.
    Pergunte ao FixBot
  11. Nintendo DSi XL Motherboard Replacement: passo 11, imagem 1 %32 Nintendo DSi XL Motherboard Replacement: passo 11, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the camera ribbon ZIF connector.
    • Use the pointed end of a spudger to pull the camera ribbon from the ZIF connector.
    Pergunte ao FixBot
  12. Nintendo DSi XL Motherboard Replacement: passo 12, imagem 1 %32 Nintendo DSi XL Motherboard Replacement: passo 12, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the touchscreen cable ZIF connector.
    • With the pointed end of the spudger, pull the touchscreen cable from its connector on the motherboard.
    Pergunte ao FixBot
  13. Nintendo DSi XL Motherboard Replacement: passo 13, imagem 1 %32 Nintendo DSi XL Motherboard Replacement: passo 13, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the backlight cable ZIF connector.
    • With the pointed end of the spudger, pull the backlight cable from its connector on the motherboard.
    Pergunte ao FixBot
  14. Nintendo DSi XL Motherboard Replacement: passo 14, imagem 1 %32 Nintendo DSi XL Motherboard Replacement: passo 14, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the lower display data cable ZIF connector.
    • With the pointed end of the spudger, pull the lower display data cable from its connector on the motherboard.
    Pergunte ao FixBot
  15. Nintendo DSi XL Motherboard Replacement: passo 15, imagem 1 %32 Nintendo DSi XL Motherboard Replacement: passo 15, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the ZIF connector for the D-Pad/power button cable.
    • With the pointed end of the spudger, pull the D-Pad/power button cable from its connector on the motherboard.
    Pergunte ao FixBot
  16. Nintendo DSi XL Motherboard Replacement: passo 16, imagem 1 %32
    • Using the flat end of the spudger, pry the battery cable up off its socket on the motherboard.
    Pergunte ao FixBot
  17. Nintendo DSi XL Motherboard Replacement: passo 17, imagem 1 %32
    • Remove the screws securing the motherboard to the upper case:
    • A single 2.5 mm silver Phillips screw
    • Four 3.7 mm black Phillips screws
    Pergunte ao FixBot
  18. Nintendo DSi XL Motherboard Replacement: passo 18, imagem 1 %32
    • Deroute the microphone and antenna cables through the slot in the motherboard.
    Pergunte ao FixBot
  19. Nintendo DSi XL Motherboard Replacement: passo 19, imagem 1 %32 Nintendo DSi XL Motherboard Replacement: passo 19, imagem 2 %32
    • Rotate the motherboard off the lower case.
    • The motherboard cannot be completely removed yet. It is still attached by the upper LCD's display data ribbon cable.
    Pergunte ao FixBot
  20. Nintendo DSi XL Motherboard Replacement: passo 20, imagem 1 %32 Nintendo DSi XL Motherboard Replacement: passo 20, imagem 2 %32
    • Using the flat end of a spudger, flip up the retaining flap on the upper display data cable ZIF connector.
    • With the pointed end of the spudger, pull the upper display data cable from its connector on the underside of the motherboard.
    • The motherboard is now free from the upper case.
    Pergunte ao FixBot
Conclusão
22 outras pessoas executaram este guia.
Brett Hartt
Membro desde: 04/12/10
132.073 Reputação
Autoria de 144 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.707 guias
1Comentário do guia
Just brilliant! Done in one go! Saved £20! Thanks indeed for good people!
Aidas - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 71
Últimos 30 dias: 407
Ao todo: 39,919
