Ir para o conteúdo principal
Nintendo DSi XL Lower Case Replacement
O que você precisa
  1. Nintendo DSi XL Lower Case Replacement, Battery: passo 1, imagem 1 %32 Nintendo DSi XL Lower Case Replacement, Battery: passo 1, imagem 2 %32
    • Remove the two Phillips screws securing the battery cover to the back of the handheld console.
    • Lift the battery cover off the back of the DSi XL.
  2. Nintendo DSi XL Lower Case Replacement: passo 2, imagem 1 %32
    • Lift the battery from the DSi XL.
  3. Nintendo DSi XL Lower Case Replacement, Lower Case: passo 3, imagem 1 %32 Nintendo DSi XL Lower Case Replacement, Lower Case: passo 3, imagem 2 %32 Nintendo DSi XL Lower Case Replacement, Lower Case: passo 3, imagem 3 %32
    • Remove the four rubber screw covers on the lower case by prying them up with a push pin.
  4. Nintendo DSi XL Lower Case Replacement: passo 4, imagem 1 %32
    • Remove the following seven Phillips screws that secure the lower case to the rest of the DSi XL:
    • Four silver 5.3 mm screws
    • Two black 5.3 mm screws
    • One black 2.5 mm screw
  5. Nintendo DSi XL Lower Case Replacement: passo 5, imagem 1 %32 Nintendo DSi XL Lower Case Replacement: passo 5, imagem 2 %32 Nintendo DSi XL Lower Case Replacement: passo 5, imagem 3 %32
    • Turn the DSi XL over, and open the display.
    • Insert a spudger between the upper and lower case at the bottom left corner of the DSi.
    • Slide the spudger along the bottom edge of the upper case to release the latches securing the upper case to the lower case.
  6. Nintendo DSi XL Lower Case Replacement: passo 6, imagem 1 %32 Nintendo DSi XL Lower Case Replacement: passo 6, imagem 2 %32
    • Close the display and turn the DSi XL over.
    • Lift the lower case from the front edge.
    • Rotate the lower case away from the DSi.
    • The lower case cannot be completely removed yet, since it is still connected to the motherboard.
  7. Nintendo DSi XL Lower Case Replacement: passo 7, imagem 1 %32 Nintendo DSi XL Lower Case Replacement: passo 7, imagem 2 %32
    • Using a spudger, pry the SD card/right shoulder button connector off its socket.
    • Pry the volume button/left shoulder button connector off its socket on the motherboard with a spudger.
Conclusão
7 outras pessoas executaram este guia.
David Hodson
Membro desde: 04/13/10
156.056 Reputação
Autoria de 127 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 64
Últimos 30 dias: 223
Ao todo: 11,282
