Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Unscrew the two Phillips screws securing the battery cover to the lower case.
Grasp the battery cover and lift it out of the lower case.
Using a spudger tool (or your fingernail), lift up the battery from the top.
Grasp the battery and remove it from the DSi.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
Remove the following screws securing the lower case to the body of the DSi:
Six 5.2 mm Phillips #00 screws.
One 2.7 mm Phillips #00 screw.
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Carefully lift the lower casing from its bottom edge.
Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
Once the cable is completely removed, then you may take off the entire outer casing.
Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
Pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
10 outras pessoas executaram este guia.
2 comentários
What causes the Wifi board to need replaced? Just age or is there a more technical explanation?
thank you! Easy to follow and awesome step-by-step instructions!
