Introdução
Unable to obtain a Wi-Fi signal? Replace the Wi-Fi board and enjoy the perks of online gaming again.
Unscrew the two Phillips screws securing the battery cover to the lower case.
Grasp the battery cover and lift out of the lower case.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Pull the Wi-Fi board away from the motherboard by its edge closest to the headphone jack.
6 outras pessoas concluíram este guia.
Um comentário
What causes the Wifi board to need replaced? Just age or is there a more technical explanation?
