Ir para o conteúdo principal
Nintendo DSi Lower Case Assembly Replacement
O que você precisa
  1. Nintendo DSi Lower Case Assembly Replacement, Battery Cover Removal: passo 1, imagem 1 %32 Nintendo DSi Lower Case Assembly Replacement, Battery Cover Removal: passo 1, imagem 2 %32
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi Lower Case Assembly Replacement, Taking out the Battery: passo 2, imagem 1 %32 Nintendo DSi Lower Case Assembly Replacement, Taking out the Battery: passo 2, imagem 2 %32
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
    This is also where the water damage indicator is located, if that's important
    Vaulto - Responder
  3. Nintendo DSi Lower Case Assembly Replacement, Lower Case Assembly: passo 3, imagem 1 %32 Nintendo DSi Lower Case Assembly Replacement, Lower Case Assembly: passo 3, imagem 2 %32
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
    One of the feet did break on me, tweezers came in handy for picking it out
    Willie Narvaez - Responder
    I unfolded and sharpened a paperclip. You can use that to stab and hook the rubber without tearing it, as the rubber is thick enough to reseal when reinserted.
    Keegan Andersen -
    Nasty, broke my spudger and the feet in this step.
    TimedIn - Responder
  4. Nintendo DSi Lower Case Assembly Replacement: passo 4, imagem 1 %32
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
    Impossible d'enlever les vises… trop serré! comment faire?
    evrobert03 - Responder
    i can't get the screw by the gamecard slot out, PH#00 is too small and PH#0 is too big
    Iblowup - Responder
    same problem here. maybe try a JIS?
    darth mango -
  5. Nintendo DSi Lower Case Assembly Replacement: passo 5, imagem 1 %32 Nintendo DSi Lower Case Assembly Replacement: passo 5, imagem 2 %32 Nintendo DSi Lower Case Assembly Replacement: passo 5, imagem 3 %32
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi Lower Case Assembly Replacement: passo 6, imagem 1 %32 Nintendo DSi Lower Case Assembly Replacement: passo 6, imagem 2 %32
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
Conclusão
8 outras pessoas executaram este guia.
Um comentário
I found that lower case ribbon cable very hard to plug back in
iSzymon - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 33
Últimos 30 dias: 158
Duração total: 13,180
