Ir para o conteúdo principal
Nintendo DSi LED Indicator Board Replacement
O que você precisa
  1. Nintendo DSi LED Indicator Board Replacement, Battery Cover Removal: passo 1, imagem 1 %32 Nintendo DSi LED Indicator Board Replacement, Battery Cover Removal: passo 1, imagem 2 %32
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi LED Indicator Board Replacement, Taking out the Battery: passo 2, imagem 1 %32 Nintendo DSi LED Indicator Board Replacement, Taking out the Battery: passo 2, imagem 2 %32
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
  3. Nintendo DSi LED Indicator Board Replacement, Lower Case Assembly: passo 3, imagem 1 %32 Nintendo DSi LED Indicator Board Replacement, Lower Case Assembly: passo 3, imagem 2 %32
    • Two screws are hidden underneath two rubber feet highlighted in red.
    • Use the tip of a spudger to pry the rubber feet out of the lower case.
    • Depending on the age of your device, the rubber feet may crumble apart as you pry them out. If so, use a fine-tipped tool to scrape out any stuck pieces of rubber.
  4. Nintendo DSi LED Indicator Board Replacement: passo 4, imagem 1 %32
    • Remove the following screws securing the lower case to the body of the DSi:
    • Six 5.2 mm Phillips #00 screws.
    • One 2.7 mm Phillips #00 screw.
  5. Nintendo DSi LED Indicator Board Replacement: passo 5, imagem 1 %32 Nintendo DSi LED Indicator Board Replacement: passo 5, imagem 2 %32 Nintendo DSi LED Indicator Board Replacement: passo 5, imagem 3 %32
    • Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
    • Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
    • Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
  6. Nintendo DSi LED Indicator Board Replacement: passo 6, imagem 1 %32 Nintendo DSi LED Indicator Board Replacement: passo 6, imagem 2 %32
    • Carefully lift the lower casing from its bottom edge.
    • The lower case is still attached to the motherboard by the volume and SD board cable highlighted in red. Do not try to completely remove the lower case of the DSi yet.
    • Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
    • Once the cable is completely removed, then you may take off the entire outer casing.
  7. Nintendo DSi LED Indicator Board Replacement, Power Board: passo 7, imagem 1 %32
    • Use the tip of a spudger to pry the power board connector out of its socket on the motherboard.
  8. Nintendo DSi LED Indicator Board Replacement: passo 8, imagem 1 %32 Nintendo DSi LED Indicator Board Replacement: passo 8, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on power board ZIF connector.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • After flipping up the locking tab on the socket, use your fingers or a pair of tweezers to gently pull the cable straight out of its socket.
  9. Nintendo DSi LED Indicator Board Replacement: passo 9, imagem 1 %32 Nintendo DSi LED Indicator Board Replacement: passo 9, imagem 2 %32
    • Remove the five 2.6 mm Phillips screws securing the power board to the DSi's framework.
    • Lift and remove the power board out of the DSi.
  10. Nintendo DSi LED Indicator Board Replacement: passo 10, imagem 1 %32 Nintendo DSi LED Indicator Board Replacement: passo 10, imagem 2 %32
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on LED indicator ZIF connector.
    • If necessary, transfer the power board ribbon cable to your new power board.
  11. Nintendo DSi LED Indicator Board Replacement, LED Indicator Board: passo 11, imagem 1 %32
    • LED indicator board remains.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 11
Últimos 30 dias: 46
Ao todo: 6,614
