Ir para o conteúdo principal
Nintendo DSi Battery Replacement
O que você precisa
  1. Nintendo DSi Battery Replacement, Battery Cover Removal: passo 1, imagem 1 %32 Nintendo DSi Battery Replacement, Battery Cover Removal: passo 1, imagem 2 %32
    • Unscrew the two Phillips screws securing the battery cover to the lower case.
    • The screws remain captive to the battery cover.
    • Grasp the battery cover and lift it out of the lower case.
    • If it's difficult to grasp, lightly tap the opposite side of the device.
  2. Nintendo DSi Battery Replacement, Taking out the Battery: passo 2, imagem 1 %32 Nintendo DSi Battery Replacement, Taking out the Battery: passo 2, imagem 2 %32
    • Using a spudger tool (or your fingernail), lift up the battery from the top.
    • There's a small tab on the top of the battery to make removal easier.
    • The liquid damage indicator sits underneath the battery. Pry gently, or you may damage the indicator.
    • Grasp the battery and remove it from the DSi.
Conclusão
19 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 80
Últimos 30 dias: 426
Duração total: 24,947
