Ir para o conteúdo principal
Nintendo DS Lite Touchscreen Replacement
O que você precisa
  1. Nintendo DS Lite Touchscreen Replacement, Battery: passo 1, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement, Battery: passo 1, imagem 2 %32
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Touchscreen Replacement: passo 2, imagem 1 %32
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
  3. Nintendo DS Lite Touchscreen Replacement, Lower Case: passo 3, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement, Lower Case: passo 3, imagem 2 %32
    • Use the tip of a spudger to pry both rubber feet off the DS Lite.
  4. Nintendo DS Lite Touchscreen Replacement: passo 4, imagem 1 %32
    • Remove the following screws securing the lower case to the body of the DS Lite:
    • Two 4.3 mm gold Phillips screws
    • One 3.9 mm black Tri-point screw
    • One 3.3 mm silver Phillips screw
    • Three 5.5 mm silver Tri-point screws
  5. Nintendo DS Lite Touchscreen Replacement: passo 5, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement: passo 5, imagem 2 %32 Nintendo DS Lite Touchscreen Replacement: passo 5, imagem 3 %32
    • Remove the cover from the Game Pak slot before continuing.
    • Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
    • Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
    • Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
  6. Nintendo DS Lite Touchscreen Replacement: passo 6, imagem 1 %32
    • Lift the lower case away from the rest of the DS Lite.
    • Pull carefully. Some units are sealed with adhesive, and pulling too hard can damage the power switch.
    • When re-assembling, make sure that power switch and volume sliders are properly aligned with the switches on the motherboard.
  7. Nintendo DS Lite Touchscreen Replacement, Trigger Buttons: passo 7, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement, Trigger Buttons: passo 7, imagem 2 %32
    • Lift both trigger buttons out of the DS Lite.
    • The trigger buttons are held in very loosely by small metal pegs and springs. Don't lose track of these pieces.
    • The second picture shows the correct configuration of the trigger assembly for reassembly purposes.
  8. Nintendo DS Lite Touchscreen Replacement, Wi-Fi Board: passo 8, imagem 1 %32
    • Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
  9. Nintendo DS Lite Touchscreen Replacement: passo 9, imagem 1 %32
    • Use the flat edge of a spudger to pry the Wi-Fi board connector straight up from its socket on the motherboard.
  10. Nintendo DS Lite Touchscreen Replacement: passo 10, imagem 1 %32
    • Use the flat edge of a spudger to separate the right edge of the Wi-Fi board from the motherboard.
    • The Wi-Fi board is secured to the motherboard with a layer of adhesive.
    • Remove the Wi-Fi board from the DS Lite.
  11. Nintendo DS Lite Touchscreen Replacement, Motherboard: passo 11, imagem 1 %32
    • Use the flat edge of a spudger to pry the microphone connector straight up from its socket on the motherboard.
  12. Nintendo DS Lite Touchscreen Replacement: passo 12, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement: passo 12, imagem 2 %32 Nintendo DS Lite Touchscreen Replacement: passo 12, imagem 3 %32
    • In the following steps you must pull the antenna cable between the DS Lite game cartridge reader and motherboard. Pull slowly and stop when you feel resistance to avoid damaging the cable or motherboard.
    • Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
    • Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
    • Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
    • When reassembling and attempting to feed the antenna cable back under the game cartridge reader, the cable may kink or become difficult to feed through. If so, try feeding a piece of thread through first; then, tie the thread to one end of the cable connector and pull it through, guiding it past any obstructions.
  13. Nintendo DS Lite Touchscreen Replacement: passo 13, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement: passo 13, imagem 2 %32
    • Use your fingernail or the edge of a spudger to carefully flip up the touchscreen ribbon cable retaining flap.
    • Make sure you are flipping up the retaining flap, not the socket itself.
    • Use the tip of a spudger to pull the touchscreen ribbon cable straight out of its socket.
    • Do not lift the flap more than 90 degrees, or you will break it off.
  14. Nintendo DS Lite Touchscreen Replacement: passo 14, imagem 1 %32
    • Remove the two 3.4 mm Phillips screws securing the motherboard to the upper case.
  15. Nintendo DS Lite Touchscreen Replacement: passo 15, imagem 1 %32
    • Open the display enough to use your finger to push the front edge of the motherboard up and away from the upper case.
    • Do not try to remove the motherboard, as it is still connected to the upper display via the upper LCD ribbon cable.
  16. Nintendo DS Lite Touchscreen Replacement: passo 16, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement: passo 16, imagem 2 %32
    • Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
    • Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
    • Remove the motherboard from the DS Lite.
    • Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
  17. Nintendo DS Lite Touchscreen Replacement, Lower LCD Assembly: passo 17, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement, Lower LCD Assembly: passo 17, imagem 2 %32
    • Use your fingernail or the edge of a plastic opening tool to carefully flip up the lower LCD ribbon cable retaining flap.
    • Pull the lower LCD assembly straight away to separate the lower LCD ribbon cable from its socket on the motherboard.
    • Remove the lower LCD assembly from the motherboard.
    • When reinstalling lower LCD, ensure it has insulation on the back to prevent a short circuit with the motherboard.
  18. Nintendo DS Lite Touchscreen Replacement, Touchscreen: passo 18, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement, Touchscreen: passo 18, imagem 2 %32
    • Insert a plastic opening tool between the touchscreen and top right corner of the display.
    • Slide the opening tool down the right side of the display to free the edge of the touchscreen.
  19. Nintendo DS Lite Touchscreen Replacement: passo 19, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement: passo 19, imagem 2 %32
    • Continue sliding the plastic opening tool along the bottom and up the left edges of the LCD to separate the touchscreen from the LCD.
  20. Nintendo DS Lite Touchscreen Replacement: passo 20, imagem 1 %32 Nintendo DS Lite Touchscreen Replacement: passo 20, imagem 2 %32
    • Lift the touchscreen away from the LCD.
    • Touchscreen remains.
    • If your replacement touchscreen doesn't come with the plastic black bezel, peel it off of your old touchscreen using the prying tool and replace it on your new touchscreen.
    • Only replace the bezel after reassembling the device; otherwise, it may be misaligned.
Conclusão
82 outras pessoas executaram este guia.
Matthew Newsom
Membro desde: 01/05/10
42.013 Reputação
Autoria de 67 guias
7Comentários do guia
There is really no reason to disconnect the upper display LCD ribbon cable. It is somewhat difficult to re-attach properly. If not attached properly the DS will not boot. The lower LCD/digitizer assembly can be removed without the need for Step 16.
Kar Wong - Responder
Fixed My Cousins DS lite touch screen using this guide. Thank You.
Michael Strine - Responder
Excellent directions! Very much appreciated. DS back in full working order. A big thanks to the additional advice in the comments, especially about attaching a thread to the antenna tho I tied it on BEFORE pulling it thru and left it in place thru rest of repair. Pulling back thru was a doddle!
Ady - Responder
When reassembling I’d suggest to pass the antenna (black wire) between the charging port and the small EM10 chip.
I first put this wire under the EM10, I couldnt close the case of the DS. There was a resistance near this spot. I gues it was the antenna wire.
Although, to put the wire under the cartridge slot, under the EM10 is the best spot. If you look under the catrige slot, you can see there is no obstacle there.
I got this wire stuck under the cartrige slot when reassembling because it was bent upward when I passed it under the slot. So it was bumping against the top of the cartrige underneath sapce. So my advice is to bend it to get it straight before feeding it through the slot. Attach it to a thread before removing it, as advised in other comments, is a good idea too. Just secure the first knot by a second one or it might detach when you pull it.
Guigui82 - Responder
This guide could have been so much shorter, no need to remove unnecessary components to get to the bottom screen.
lowestseries - Responder
Comentar
Visualizações:
Últimas 24 horas: 74
Últimos 7 dias: 523
Últimos 30 dias: 1,912
Ao todo: 155,414
