Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Use a Phillips #00 screwdriver to remove the screw securing the battery cover.
Use a spudger to pry out the battery.
Pry off the rubber feet.
Remove the seven screws securing the lower case:
Three tri-wing screws
One Phillips screw
Two gold Phillips screws
One black tri-wing screw
Carefully pry the bottom cover off.
Remove the shoulder buttons by pulling out the metal pegs that secure them to DS.
You can now access the micro-button component and replace or repair anything as needed.
5 outras pessoas executaram este guia.
3 comentários
For anyone dealing with unresponsive shoulder buttons, I highly recommend watching this video guide;
https://www.youtube.com/watch?v=VnWdawXC...
たしかにそうですね!!!
kawagoe -
