Introdução
So you spilled water on your DS Lite and fried the motherboard - sad day! But don't fret, just replace the motherboard and get back into the game!
Peças
Nenhum componente especificado.
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
Use the flat edge of a spudger to pry the Wi-Fi antenna connector straight up from its socket on the Wi-Fi board.
Use the flat edge of a spudger to pry the microphone connector straight up from its socket on the motherboard.
Position the antenna cable with its connector facing up and away from the motherboard using a spudger to hold it down lightly in the gap between chips on the motherboard.
Slowly and carefully pull the antenna cable until the cable connector is under the DS Lite game cartridge reader.
Continue pulling the cable until the cable connector comes out from under the game cartridge reader on the right side.
Use your fingernail or the flat edge of a spudger to carefully flip up the upper LCD ribbon cable retaining flap.
Pull the motherboard away from the DS Lite to separate the upper LCD ribbon cable from its socket on the motherboard.
Remove the motherboard from the DS Lite.
Now you may open the retaining flap for the lower LCD screen in the same way and separate the lower LCD screen from the motherboard.
53 outras pessoas concluíram este guia.
5 comentários
Hey I took my do lite apart to repair the mic but then I saw that it would be risky do I put it back to tether carefully and now when it turns in the bottom LCD screen flickers then shuts down after the two speakers make a tiny pop sound, I did plug the top LCD screen cable back in but now I'm sad cause it's my first ever do before my 3ds, please help
Just checking but did you make sure to reinsert the tiny ribbon cable from step 13? might be something tiny you overlooked?
enekuda -
Is there any way to replace the socket for the touch screen? I bought a used DS lite with a non working screen and when I opened it I found out that the flap was broken
Hi, I was trying this and everything works, but my left trigger button on the motherboard came off. I tried resoldering it and test it and it works… too well. As in it's constantly being pressed on, or it's registering constant button presses, even though it's not being pressed on. When I resoldered it, it only had 2 metal contact pins at the bottom. If I can get help for this as soon as possible, the repair will be complete.
