Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replace your Nintendo DS Lite lower case to make it look straight-from-the-store new!
O que você precisa
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
Insert the edge of a spudger in between the lower and upper case near the top right corner of the DS Lite.
Carefully run the spudger along the right edge of the DS Lite, creating an opening in the process.
Continue running the spudger along the backside of the DS Lite until the majority of the lower case has been separated from the upper case.
33 outras pessoas executaram este guia.
