Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Has your DS Lite battery stopped providing the game time you deserve? Replace the battery to free yourself from the wall charger.
O que você precisa
Unscrew the Phillips screw securing the battery cover to the lower case.
Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
46 outras pessoas executaram este guia.
5 comentários
Can you describe the type of screw and captive washer ?
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
