Ir para o conteúdo principal
Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Nintendo DS Lite Battery Replacement
O que você precisa
  1. Nintendo DS Lite Battery Replacement, Battery: passo 1, imagem 1 %32 Nintendo DS Lite Battery Replacement, Battery: passo 1, imagem 2 %32
    • Unscrew the Phillips screw securing the battery cover to the lower case.
    • The screw remains captive to the battery cover.
    • Pry the battery cover upward with a spudger or fingernail, and lift out of the lower case.
  2. Nintendo DS Lite Battery Replacement: passo 2, imagem 1 %32
    • Wedge the edge of a spudger in between the side of the battery and the lower case housing and pry upward to dislodge the battery.
    • Remove the battery from the DS Lite.
Conclusão
46 outras pessoas executaram este guia.
Matthew Newsom
Membro desde: 01/05/10
39.500 Reputação
Autoria de 67 guias
5 comentários
Can you describe the type of screw and captive washer ?
Cornel Paraschiv - Responder
Thank you.
i just ordered a new battery as I already got a new power cord & it won’t charge at all.
Hoping new battery does the trick.
Thanks again.
T. Kellogg
Tamela Kellogg - Responder
Thanks but will a dsi battery work
Zach - Responder
My battery cover won’t come off.
Jake - Responder
Flip the console upside down and it will but don’t pull it will break hold it close to the console then slide it back
dead -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 33
Últimos 7 dias: 176
Últimos 30 dias: 916
Duração total: 53,307
