Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
After removing the circuit board, the bottom LCD screen can easily be removed from the Nintendo DS.
  1. Remove the cartridge from the console. Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case. Remove the battery door.
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case.
    • Remove the battery door.
  2. Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
  3. Remove the battery from the Nintendo DS.
    • Remove the battery from the Nintendo DS.
  4. Remove the seven Y0 screws located on the back.
    • Remove the seven Y0 screws located on the back.
    • It might be helpful to remove the strap from the hole to access the top left screw.
  5. With your hands, pry the back panel off the main case. Separate the back from the front, and set it aside. Separate the back from the front, and set it aside.
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
  6. Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Using a Phillips #00 screwdriver, remove the four screws on the circuit board.
    • Be careful NOT to slip with the screwdriver, you can damage the circuit board!
  7. Unlock the two large ribbon cables by moving the black clip up. Carefully pull the ribbon cables down and out with your fingers. Do not use pliers to pull the cables, as they can be damaged easily.
    • Unlock the two large ribbon cables by moving the black clip up.
    • Carefully pull the ribbon cables down and out with your fingers.
    • Do not use pliers to pull the cables, as they can be damaged easily.
  8. Locate the two small ribbon cables, beneath the rightmost large ribbon cable. Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • Locate the two small ribbon cables, beneath the rightmost large ribbon cable.
    • Slide the locks for the small ribbon cables down to the side, and remove the cables.
    • It may be useful to use tweezers to remove the small ribbon cables.
    • Be careful not to damage the delicate ribbon cables.
  9. Locate the Wifi antenna pigtail connector. Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
    • Locate the Wifi antenna pigtail connector.
    • Remove the antenna by grasping it at the head with tweezers. Using a slight rocking motion, pull up to dislodge the connector.
  10. Feed the ribbon cables through the opening on the board.
    • Feed the ribbon cables through the opening on the board.
    • Pull up and remove the circuit board, and set it aside.
  11. Peel off the back foam on the bottom touch screen to expose the ribbon cable. Gently lift the screen out of the base.
    • Peel off the back foam on the bottom touch screen to expose the ribbon cable.
    • Gently lift the screen out of the base.
Conclusão
9 outras pessoas concluíram este guia.
dnguye26
Membro desde: 28-10-2009
427 Reputation
4 Guias de autoria
Equipe
Cal Poly, Team 18-3, Maness Fall 2009 Membro de Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Membros
11 Guias de autoria
I like it but add a step 12 maybe, to see how to put in a new screen.
Zackary Benton - Responder
Adicione um comentário
Past 24 Hours: 8
Past 7 Days: 32
Past 30 Days: 158
All Time: 30,871
