Pular para o conteúdo principal
Introdução
Removing the back panel is simple, provided you have the correct screwdriver. Nintendo uses a special Tri-wing bit for the case, be sure you have one of these before disassembling!
  1. Remove the cartridge from the console. Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case, turning the screw counter-clockwise. Remove the battery door.
    • Remove the cartridge from the console.
    • Use a Phillips #00 Screwdriver to remove the screw securing the battery door to the rear case, turning the screw counter-clockwise.
    • Remove the battery door.
  2. Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
    • Use a plastic opening tool or spudger to pry out the battery from the bottom. If a plastic open tool or spudger isn't available, your fingernails may work.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Comprar agora
    PC Laptop Batteries
    Comprar agora
  4. Remove the battery from the Nintendo DS.
    • Remove the battery from the Nintendo DS.
  5. Remove the 7 Y0 screws located on the back.
    • Remove the 7 Y0 screws located on the back.
    • It might be helpful to remove the strap from the hole to access the top left screw.
  6. With your hands, pry the back panel off the main case. Separate the back from the front, and set it aside. Separate the back from the front, and set it aside.
    • With your hands, pry the back panel off the main case.
    • Separate the back from the front, and set it aside.
Conclusão
9 outras pessoas concluíram este guia.
dnguye26
Membro desde: 28-10-2009
385 reputação
4 Guias de autoria
Equipe
Cal Poly, Team 18-3, Maness Fall 2009 Membro de Cal Poly, Team 18-3, Maness Fall 2009
CPSU-MANESS-F09S18G3
4 Membros
11 Guias de autoria
Where do I get a nintendo DS gamepak?
Kayla Maison - Responder
Adicionar comentário
Visualizar Estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 13
Últimos 30 dias: 43
Todo: 12,864
