Ir para o conteúdo principal
Nintendo 64 Motherboard Replacement
O que você precisa
  1. Nintendo 64 Motherboard Replacement, Top Cover: passo 1, imagem 1 %32
    • Remove the expansion pack cover by pushing in the tab and pulling out.
    Pergunte ao FixBot
    Comentar
  2. Nintendo 64 Motherboard Replacement: passo 2, imagem 1 %32
    • If your system uses a jumper pack, the same procedure applies to remove it.
    • A small spoon can be used in place of a spudger.
    • Lever the expansion pack out using a metal spudger.
    Pergunte ao FixBot
    Comentar
  3. Nintendo 64 Motherboard Replacement: passo 3, imagem 1 %32
    • Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
    Pergunte ao FixBot
    Comentar
  4. Nintendo 64 Motherboard Replacement: passo 4, imagem 1 %32
    • Remove the two front feet of the N64.
    Pergunte ao FixBot
    Comentar
  5. Nintendo 64 Motherboard Replacement: passo 5, imagem 1 %32
    • Rotate to top side up and lift off top cover.
    Pergunte ao FixBot
    Comentar
  6. Nintendo 64 Motherboard Replacement, Metal Plate: passo 6, imagem 1 %32 Nintendo 64 Motherboard Replacement, Metal Plate: passo 6, imagem 2 %32
    • Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  7. Nintendo 64 Motherboard Replacement: passo 7, imagem 1 %32 Nintendo 64 Motherboard Replacement: passo 7, imagem 2 %32
    • Remove the metal plate indicated in the example by sliding it back and then lifting it up.
    Pergunte ao FixBot
    Comentar
  8. Nintendo 64 Motherboard Replacement: passo 8, imagem 1 %32
    • Remove the two screws indicated in the example using the smaller Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  9. Nintendo 64 Motherboard Replacement: passo 9, imagem 1 %32
    • Remove the screw to the right of the LED light using the larger Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  10. Nintendo 64 Motherboard Replacement: passo 10, imagem 1 %32
    • Remove the small metal bracket from the back of the expansion pack slot.
    Pergunte ao FixBot
    Comentar
  11. Nintendo 64 Motherboard Replacement: passo 11, imagem 1 %32 Nintendo 64 Motherboard Replacement: passo 11, imagem 2 %32
    • Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
    Pergunte ao FixBot
    Comentar
  12. Nintendo 64 Motherboard Replacement: passo 12, imagem 1 %32 Nintendo 64 Motherboard Replacement: passo 12, imagem 2 %32
    • Remove the small metal bracket behind the expansion slot using the spudger.
    Pergunte ao FixBot
    Comentar
  13. Nintendo 64 Motherboard Replacement: passo 13, imagem 1 %32 Nintendo 64 Motherboard Replacement: passo 13, imagem 2 %32
    • Remove the seven screws indicated in the example using the larger Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  14. Nintendo 64 Motherboard Replacement: passo 14, imagem 1 %32
    • Lift off and remove the metal plate as indicated in the example.
    Pergunte ao FixBot
    Comentar
  15. Nintendo 64 Motherboard Replacement, Motherboard: passo 15, imagem 1 %32
    • Remove the four screws indicated using the #1 Phillips screwdriver.
    Pergunte ao FixBot
    Comentar
  16. Nintendo 64 Motherboard Replacement, Motherboard removal: passo 16, imagem 1 %32
    • Lift up and remove the motherboard.
    Pergunte ao FixBot
    Comentar
Conclusão
41 outras pessoas executaram este guia.
tonymag28
Membro desde: 10/28/09
2.309 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-4, Regan Fall 2009 Membro de Cal Poly, Team 5-4, Regan Fall 2009
CPSU-REGAN-F09S5G4
7 Membros
Autoria de 20 guias
3Comentários do guia
4.2mm doesn't seem right. When I looked to purchase all I saw was 4.5mm and now that I have one in my hand it seems to fit very precisely on the screws on my N64.
negroslim - Responder Compartilhar
i got the second comment :whyy:
Sqwerks - Responder Compartilhar
What are the symptoms of a bad motherboard?
Jon - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 7
Últimos 7 dias: 58
Últimos 30 dias: 318
Ao todo: 72,129
