Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the expansion pack cover by pushing in the tab and pulling out.
Lever the expansion pack out using a metal spudger.
Remove the six screws on the bottom side indicated in the example with a gamebit head or screwdriver.
Remove the fourteen screws indicated in the example using the larger Phillips screwdriver.
Remove the metal plate indicated in the example by sliding it back and then lifting it up.
Remove the two screws indicated in the example using the smaller Phillips screwdriver.
Remove the screw to the right of the LED light using the larger Phillips screwdriver.
Remove the small metal bracket from the back of the expansion pack slot.
Remove the small metal bracket from the front of the expansion pack slot with the metal spudger.
Remove the small metal bracket behind the expansion slot using the spudger.
Remove the seven screws indicated in the example using the larger Phillips screwdriver.
Lift off and remove the metal plate as indicated in the example.
5 outras pessoas executaram este guia.
